Go to Post "The only constant is change" is a hint that probably applies to every season of FIRST. - Chris is me [more]
Unread 06-01-2008, 17:12
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Trackball inflation
I was looking through the manual, and found the instructions on how to blow up the ball. I also noticed that they showed pictures of what the ball SHOULD look like when it is under-filled, correctly filled, or over-filled. I dont like this because the amount of air in the ball could make a huge difference, and I dont think that it should be determined by "I think this looks right". Has anyone seen if they say how much air to put in it instead of just pictures? I really hope that they do, and that I just missed it, or that they are going to come out with something in an update.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 06-01-2008, 17:28
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Trackball inflation
From last year's experience with the inflatable tubes, I strongly suggest you make you robot so it will work with underinflated, correctly inflated, and overinflated track balls.
Unread 06-01-2008, 17:34
AKA: Joey
I completely agree. Last year for tubes however at the competitions they had gauges to fill the tubes so they had exactly the same fill. I dont remember if they told teams ahead of time how full they would be though. I know the balls may deflate through out the matches, but I feel that all balls should start with the same fill, and if they get so low that you can notice a difference, they should be refilled.
Joey
Unread 06-01-2008, 18:26
BandChick's Avatar
BandChick BandChick is offline
Superpower: Knows Everyone
AKA: Sara Reffler
FRC #1089 (Team Mercury)
BandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond repute
Send a message via AIM to BandChick
Last year, it was written in the manual what approximate inflation was, but even at regionals, tubes were under and over inflated. When you're in a rush to reset and you need tubes (or balls, or anything else that's inflated), you don't always have the time to check for perfection.
Tubes that started filled and had small holes/leaks, were underinflated by the time many teams went to pick them up anyway. Expect a few completely deflated balls too, with some very large holes.
Balls/tubes actually are refilled during a competition. Usually the day before everything is inflated, and then as things get really underinflated they're replaced with new game objects, refilled, and used again later.
2016 Championship userbars are here!
1089 Mentor & Alum | 2016 MAR Championship Finalists, Innovation in Control Award Winners
2015 Archimedes Champions | 2015 Einstein Semi-Finalists
2014 MAR Championship Finalists | 2014 Bridgewater District Finalists | 2013 Lenape District Finalists | 2011 NJ Regional Finalists
2014 & 2015 Excellence in Engineering Award | 2014 Xerox Creativity Award
2009, 2011, 2013 KCP&B Entrepreneurship Award Winners | 2012 Gracious Professionalism Award Winners | 2009 NJ Regional Chairman's Award Winners
"Success in life is a matter not so much of talent or opportunity as of concentration and perseverance." C.W. Wendte
Unread 06-01-2008, 19:55
MasterMkanik's Avatar
MasterMkanik MasterMkanik is offline
AKA: Cameron
FRC #0619 (CARobotics)
MasterMkanik is an unknown quantity at this point
Well, you can always find the circumference of the ball is supposed to be and then physically measure the distance around the ball, and make sure they match.
He's on the Fruit Loops side of the cereal aisle... if you know what I mean.
My mind works like lightning, one brilliant flash and it's gone
Unread 06-01-2008, 19:59
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
oooooooo..... good idea, didn't think of that.
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 06-01-2008, 20:07
Mike@1023 Mike@1023 is offline
Rookie
AKA: Michael Cononie
FRC #1023 (Bedford Express)
Team Role: Student
Mike@1023 is an unknown quantity at this point
Send a message via AIM to Mike@1023
even though you want to get the trackballs at the correct size, there will be some variation at competition. when they are that big, the differences are bigger than, say if they were, 12 inches. 10% bigger on a trackball is four inches, and on a 12 inch ball would only be 1.2 inches. So leave a margin for variables.
Unread 06-01-2008, 20:14
Miniflash's Avatar
Miniflash Miniflash is offline
AKA: Gordon Wyant
FRC #2028 (Deep Impact)
Team Role: Human Player
Miniflash is on a distinguished road
it took me forever to pum the dang thing up yesterday. my compressor broke so i did it with a foot pump... my legs are so sore.. who knew a ball needed that much air
Unread 09-01-2008, 22:18
davidfv davidfv is offline
FRC #0399 (Eagle Robotics)
Team Role: Tactician
davidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant future
ANyone know where to get more trackballs???
Davidfv
Mentor/Drive Coach
Unread 09-01-2008, 22:23
Elgin Clock's Avatar
FRC #0237 (Black Magic)
No. That seems to be the "million dollar question" this year so far.
FIRST has not released an official source to get spares and/or replacements as of yet..
Hopefully they will soon though with the staggering amount of requests we've seen here.
Unread 10-01-2008, 10:22
pfreivald's Avatar
AKA: Patrick Freivald
The balls look very similar to an 'Omnikin Ball' that we have in our gymnasium -- complete with poly-canvas cover. Typically, the balls are 48" in diameter, but I've found some 40" Omnikin balls on the net.
http://www.athleticimpact.com/ba552.html
http://www.sportsdirectsource.com/products/359
....unfortunately, neither one gives the precise weight.
Patrick
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 10-01-2008, 13:33
Sqwigy Sqwigy is offline
AKA: Erik
FRC #1591 (Greece Gladiators)
Sqwigy is an unknown quantity at this point
Let's see now, we got our kit on. . . Saturday. Our team met 3 times or so since then, it's now thursday so it hasn't even been a week. AND we have popped our trackball. We are very efficient if I do say so myself.
We're doing our best to patch it and it's turning out well. By the way we popped it tuesday, yeah thats right 3 days.
Unread 10-01-2008, 13:48
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
As a former gauge engineer.... why don't they come up with a simple set of GO/NO GO gauges? The GO would tell you if the trackball is too big in diameter and the NO GO would tell you if the trackball is too small in diameter. By passing through the GO, you would know the trackball was not too big and by not passing through the NO GO, you would know that the trackball was not too small. The gauges could be as simple as two pieces of lexan, if you wanted a 40" diameter trackball, one would have a 41" hole (GO, not larger than 41") and one would have a 39" hole (NO GO, not smaller than 39").
If you are more concerned with bounce/air pressure, a simple pressure gauge would work.
Unread 10-01-2008, 14:01
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
As in previous years, the design of the robot should be robust enough to account for variances in trackball size and weight. Competitions are too dynamic to spend time measuring and adjusting trackballs between every match. Precision has its place in robotics, but interaction with real world environments is not it!
Be assured that every match will start out with big giant red and blue trackballs and they will be ABOUT 40" in diameter and ABOUT 10 pounds. They may even be approximately spherical!
Unread 13-01-2008, 12:37
BandChick's Avatar
AKA: Sara Reffler
Keep in mind, FIRST competitions run on a very tight schedule.
FRC matches are usually about 6 minutes from start to start. 6 minutes for reset, unloading and reloading robots, and making sure the scoring system is ready to go. And that 6 minutes goes by VERY quickly. There just isn't enough TIME to check to make sure everything is perfect.
Generally, the folks on field reset are told to keep an eye out for anything that looks seriously deflated, or anything with a hole in it. But expect there to be some that are only inflated to about 36" to still be on the field.
There was one year that we had a box to make sure balls were the right size, but that being said, it was only for initial inflation.
And most regionals didn't use it. It's just time consuming, that's all there is to it.
Enevitable- Trackball popped pheadxdll Kit & Additional Hardware 30 03-02-2008 08:08
Trackball scoring ZP8892 Rules/Strategy 6 06-01-2008 08:52
change in trackball size Dan Zollman Rules/Strategy 1 06-01-2008 00:22
Intertube inflation? G-Ball Rules/Strategy 6 09-02-2007 13:48
game ball inflation archiver 2000 5 23-06-2002 22:28
