Go to Post Every robot is a key element to each victory, no matter how much or how little they help. - JosephC [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 21:55
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
acrobat files are in the mail...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 8/24/99 8:10 PM MST
In Reply to: On-board chip spec's posted by Matt Rizzo on 8/23/99 1:13 PM MST:
Matt,
I am mailing you the specs you asked for. Good luck.
BTW, the SSC that FIRST uses is not quite an off the shelf unit. They use a faster crystal
(16Mhz vs 8Mhz as I recall) and they communicate with the Slave CPU (our CPU) at a
correspondingly faster baud rate (19200 vs 9600 again if memory serves).
Good luck.
Joe J.
[IMG] code is Off
Shelf and board dimensions still don't add up kmcclary Off-Season Events 12 20-10-2001 09:12
