Go to Post If you are old then our lead mentor is ancient. Oh wait, he is. Oh wait, that makes me ancienter. - JaneYoung [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 06-01-2008, 21:17
Jaybee1405
Posts: n/a
Kitbot pros and cons
In my teams first three years, we used the "Kitbot" with modifications for gamepiece manipulation. Last year, we welded our own frame and it worked out really well for us because we were defensive minded. The frame was solid as a rock and we never had to worry about losing nuts and bolts.
This year, we're considering going back to the Kit frame because speed is so vital and the Kit parts are so light.
What are your thoughts on the Kitbot? Any pro's or con's of using that opposed to welding your own frame?
Thanks,
Joe & Team 1405
Unread 06-01-2008, 21:20
Re: Kitbot pros and cons
Pros:
-cheap
-easy to put together
-versatile
-tough
Cons:
-"robot droppings" may weaken it
Unread 06-01-2008, 21:28
Jaybee1405
Posts: n/a
Is it weldable? The "robot droppings" problem would thus be eliminated
Unread 06-01-2008, 21:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I think we'll be going with the kitbot frame ourselves this year primarily to speed drive train development and completion. If we do, our plan to combat robot droppings and weight is to use 1/4" pop rivets instead of the screws and nuts, as several other teams have had good success with.
Unread 06-01-2008, 21:49
run the trap!!!
Team Role: Human Player
If you do decide to use the kit-bot, turn it upside down and use smaller wheels. There's no need for 2"+ of ground clearance this year. This will lower your CG, making your robot faster and sturdier.
-Philip J. Fry
Unread 06-01-2008, 21:55
Jaybee1405
Posts: n/a
I think we're planning on 6" wheels so we can increase our velocity. Acceleration may take a hit but velocity is so vital this year.
But thanks for the tip in turning it upside-down, I'll bring it up with out team.
I'm still wondering, is it weldable??
Unread 06-01-2008, 21:58
run the trap!!!
Yes. It is easy to weld. I welded some of the Kit-bot stock together last year.
-Philip J. Fry
Unread 06-01-2008, 21:59
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Yes, you can weld it.
Unread 06-01-2008, 22:02
Jaybee1405
Posts: n/a
awesome, sounds like a plan
thanks everyone
Unread 06-01-2008, 22:17
Mark Pendergast Mark Pendergast is offline
FRC #1760 (Robo-Titans)
Mark Pendergast will become famous soon enoughMark Pendergast will become famous soon enough
<SNIP> we never had to worry about losing nuts and bolts. <SNIP>
Thanks,
Joe & Team 1405
Use Loctite Threadlocker Red on all the bolts - It is almost as good as welding. (I believe it mentions this in the Kitbot instructions somewhere.)
http://loctiteproducts.com/repairs.a...=5&Product=154
Unread 06-01-2008, 22:31
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Personally I love the kitbot frame. We tried to make our own frame last year but we ended up ditching it for the kitbot.
Pros:
Relatively light
Predrilled for six wheel drive
lots of holes to mount stuff
Cheap
Almost bullet-proof
Cons:
Not heavy enough for a primarily defensive bot (IMO)
-Dustin Benedict
Unread 06-01-2008, 22:33
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
I was thinking it would be good to make it low too, but don't the bumper zone rules make that difficult?
Unread 06-01-2008, 22:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Bumper zone is 2.5 to 8.5" from the floor, and the frame is really skinny, so that might be an issue. You could make brackets to mount the bumpers though.
I wonder how the kitbot frame would work with Ackerman (car type) steering?
Unread 06-01-2008, 22:52
Jaybee1405
Posts: n/a
Same thing we're wondering. We'll probably have to cut away some space in the front so the wheels will have room to turn.
Unread 06-01-2008, 22:57
Billfred's Avatar
Billfred Billfred is offline
I'd be wary of cutting away too much from the kit frame; when we tried going open-front at BE, it was not really as effective as the whole frame together. I'm not saying it's impossible, I'm just saying to be careful.
Another option, if you have access to facilities that can do sheetmetal work, could be to take the drawings of the kit end caps and get new, wider ones made. I believe that IFI has the drawings on their website.
6WD Pros and Cons ChuckDickerson General Forum 59 13-01-2008 02:20
Two cameras: Pros and Cons cooknl Programming 1 12-01-2006 20:57
Motor Placement Pros and Cons Pattie Motors 17 24-01-2005 15:40
Timing belts pros and cons!!!! archiver 2001 3 24-06-2002 00:33
Buckeye Regional PROS and cons emilywll Regional Competitions 14 18-03-2002 10:04
