Go to Post Yes, machining a dog profile into a steel sprocket on a manual mill was an experience filled with pain and regret. - Joe G. [more]
Unread 06-01-2008, 21:43
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
Re: Bouncing TrackBalls
Unfortunately we dropped the ceiling in our lab (formerly ~30ft) to the point where we can only get the trackball's bottom about 5' off the ground, but our (limited) bounce testing shows that they have a coefficient of restitution (bounciness) of somewhere between 1/2 and 2/3, that is each bounce is about .6 times as high as the previous.
That sounds like a lot of... fun.
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Unread 06-01-2008, 21:52
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
So about 4 feet... .6 times as high each bouce... after about 4-5 bounces it might be able to grab IF it doesnt bounce out of the arena... given the only open areas are where the robots are dragged in...
Im to tired to do the math oh how long it would take for it to hit the wall and start bouncing back...parabolas and such...
This might actually give an advantage to robots that are trying to grab and carry them... robots pushing them will have to try and follow it around as it bounces off of walls and robots and such. I dont know that was probably obvious beforehand im just tired... Man only like 2 days in and im already behind on sleep...
Last edited by GBilletdeaux930 : 06-01-2008 at 21:55. Reason: Forgot the word out in "out of the arena"
Unread 06-01-2008, 22:06
danshaffer's Avatar
Stanford 2012
Well basic kinematics shows that the height of each bounce doesn't matter at all for the time that it will take to hit the wall, just the velocity with which it is released as it is hurdled.
The bouncing height will increase the contact/normal force and thus the friction, but the ball wasn't going to be sliding anyway, presumably it would just start rolling.
Unread 06-01-2008, 22:10
AKA: Greg
ok... so my mind doesnt function well when its tired... lol
so anyways...any ideas on how you would control this or beable to gain control of it while it's bouncin...
Unread 06-01-2008, 22:23
danshaffer's Avatar
Stanford 2012
well you either have to have a solid grabber to take control of it or otherwise just have a big pusher and don't worry about the bounces...
Unread 06-01-2008, 22:29
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
FRC #0177 (Bobcat Robotics)
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
One easy way to deal with grabbing a moving object is rollers. With a powerful enough mechanism, all you would need to do is touch the ball to grab it. The problem is designing a powerful enough mechanism.
Once a Bobcat, always a Bobcat
2001-2004: Student
(I'm told the team had a couple good years in between here)
2012 - Present: Mentor
Unread 08-01-2008, 00:41
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
http://www.youtube.com/watch?v=o4bAuLg7ZmE
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 08-01-2008, 20:43
tuzzer tuzzer is offline
AKA: Matthew Chan
FRC #1558 (ACCIdent)
tuzzer is an unknown quantity at this point
It doesn't seem too bad. It's not really that hard to catch
Trackballs chaineezee General Forum 67 25-01-2008 11:10
Balls bouncing out of goal Bob Steele Regional Competitions 31 08-03-2006 13:00
Bouncing turns bob1million Technical Discussion 34 01-03-2004 16:40
Bouncing heads.... archiver 2001 2 24-06-2002 00:14
