Go to Post It's a good things we're engineers who regularly squeeze out 'miracles' with a severely limited budget, eh? I think that's an important aspect that we as mentors need to show the students from time to time, and this year is a perfect opportunity. - JesseK [more]
Unread 06-01-2008, 21:56
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
Re: IR Remote Interference
the problem with IR, is that the further you get back from the intended target (our robots) the wider the spectrum band is. The year we were introduced to IR during a FIRST competition they suggested that we use a bic pen to focus the ir signal to the ball drop pedestals. This worked, only because we were seeking out the same signal. This year where we will be transmitting multiple signals at the same time, it won't matter how we focus/defuse/ or "up" our signal. We will still be intefering by having multiple signals at thesame time..
Unread 06-01-2008, 22:37
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Originally Posted by Andy Goetz View Post
Couldn't a team just use a protective hood on IR Sensor? The robot could us a compass or a gyroscope combined with a turret to keep the sensor pointing at the RoboCoach area.
That is a very cool idea.
Unread 07-01-2008, 00:13
Gdeaver Gdeaver is offline
FRC #1640
The IR interference is going to be a problem. Dave did point out that sound and light are also options. If key is for a team to use a fequency that no other team would think to use.
Unread 07-01-2008, 00:32
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
If only for this reason, lets not use our remotes as joysticks in another tele-operated period! If your design calls for buttons to be held down, you may want to rethink it to give your alliance partners a chance to send commands to their robots.
If alliances split robocoaches between the stations, use tubes to make their remotes directional, and treat the signals as commands and not a direct controller (such as "investigate that rock" and not "drive forward while I hold this button down"), IR should work. Pretend your robot is like Dave's, and on Mars. Another tele-operated period is not the intent of the hybrid period!
Having "start moving forward" and "stop" buttons would work better for everyone than moving forward while the button is held down, with the same effect. Let's practice gracious professionalism with our hybrid control designs!
That said, other mediums for command transmission would be great fun and potentially less prone to interference. Let's see the light and ultrasonic stimuli! (We might have to ask people to please not use flashlights or jingle keys near our robot )
Unread 07-01-2008, 00:44
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Originally Posted by Stillen View Post
i just tired this at home. It appears this WILL be a problem..... If two infrared commands are issued at overlapping times, even if they are different frequencies they cancel each other out...
I have also tested this and found the same thing. Summary of my tests can be found in this thread: http://www.chiefdelphi.com/forums/sh...737#post670737
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 07-01-2008, 22:11
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
But the interfering remotes will also be in the RoboCoach area.
Unread 10-01-2008, 12:36
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
So - the really big question is has ANYONE figured out how to avoid the IR interference from other remotes? I'm not looking for a theoretical answer but one that has been tested and proven to work. This has to be possible if they are included it in part of the game - I'm assuming someone has figured it out.
Unread 10-01-2008, 13:00
FRC #1640
The key to reliable Hybrid comunications is to use a fquency band that no other team is using. We have sound, visible light and IR.
Unread 12-01-2008, 11:22
ida_noeman's Avatar
ida_noeman ida_noeman is offline
AKA: phobbs
FRC #1719 (Umbrella Corp.)
ida_noeman is on a distinguished road
Lol you could also use a huge elliptical dish!
"Weeks of coding can save you hours of planning"
"If the code was hard to write, I'm dam well going to make it hard to read!"
Unread 12-01-2008, 12:50
Glooper's Avatar
Glooper Glooper is offline
Annoying Blob of Goo
AKA: Alec
FRC #1719 (Umbrella Corporation)
Glooper is an unknown quantity at this point
Just wondering, do the remotes have to be pointed at the same robot to recieve interference?
Blood rains from above
A wave of death consumes all
Sadness is but life
Unread 13-01-2008, 12:34
steve d steve d is offline
FRC #1277
steve d is an unknown quantity at this point
We're going to make a remote and use our own code. We'll use a BasicStamp and an IR transmitter to blast out our own "secret" code.
Unread 14-01-2008, 17:28
robotrobot2's Avatar
robotrobot2 robotrobot2 is offline
Computer Overlord
FRC #0151 (Tough Techs)
robotrobot2 is on a distinguished road
The problem is that multiple IR signals give constructive or destructive interference. Even if the two receivers are set to different frequencies, the second frequency will be slightly changed by the first, an vice versa. The only way to really fix this is by using using an absurdly high frequency, (almost actual red) and increasing the window at which the receiver will respond.
Everything can always be blamed on software:
The claw can't pick up the trackball-
programmers must have messed up the claw function.
The driver crashes the robot into a wall-
the drive code must not be responsive enough.
The robot repeatedly displays "HELLO WORLD"-
that probably is software.
Unread 14-01-2008, 17:51
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
>This could well be a problem. But, it probably could be solved by "boosting" the >signal from your remote. Ie. wiring more IR LED's in series. (or is it in parallel?)
>anyway, once more IR LED's are soldered on your remote, it will effectively >double or triple the range of your remote.
I don't think it works that way (but could be wrong). To get a greater range, you'll need higher intensity. The light from multiple LEDs won't add constructively unless the wavefronts are perfectly aligned (quite hard to do). You can increase the intensity by increasing the current through the LED (up to a point, check the data sheeet) or using a different LED. But this may or may not be allowed as it can become unsafe at some point.
HTH,
Keith
Unread 15-01-2008, 13:48
JHSmentor's Avatar
FRC #3210 (Falcons)
one way of looking at the interference factor is that it forces the teams to be cooperative. The robocoach area will only have members of your direct alliance. this will require some coordination from these members to make sure only one transmits at a time. Eliminating the noise from the other alliance is easy enough by having a directional cone pointed only at the robocoach area.
of course, without a turret to point the cone, this will only work up to the first turn in the course - by then, maybe it does not matter.
other than that, I have not seen any discussion in other threads of a more robust solution. Of course, this does not take into account other types of communication (light and sound).
IR Interference neutrino15 Technical Discussion 4 07-01-2008 19:21
Interference Jeremiah Johnson VEX 8 30-08-2006 07:32
Remote Remote Kickoff for Southern California ChrisH Southern California Regional Robotics Forum 0 05-01-2004 12:36
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
Robot Controller Interference? Mr. Van Technical Discussion 20 22-11-2002 17:18
