Go to Post I happen to know that there is a back-order status from Exide. Seems for some reason people are ordering this product - Mike Martus [more]
Unread 06-01-2008, 01:45
atowle1236 atowle1236 is offline
FRC #1277
atowle1236 is an unknown quantity at this point
Remote troubles
What would work better, acoustic or infrared frequencies for sending a message to the robot?
Also, is it a better idea to make your own remote or cannibalize an existing remote to perform your functions?
Unread 06-01-2008, 04:54
dtengineering's Avatar
AKA: Jason Brett
Re: Remote troubles
You would not need to cannibalize an existing remote... most any $2 multibrand remote control that you pick up at a surplus store (or any $10 one you pick up at an electronics store) will have at least one protocol that will work with the receiver.
As to which is the best way to communicate with your robot... well, that's the crunch, isn't it?
Jason
Unread 06-01-2008, 22:22
Dr.Tucker Dr.Tucker is offline
AKA: Dodge
FRC #1307 (RoboSaints)
Dr.Tucker is an unknown quantity at this point
Re: Remote troubles
To test your infrared signals use the camera in your cellphone. If its aimed at the IR transmitter you can actually see the infrared light in the screen. I dont know if this will assist you but its just a helpful hint.
Unread 07-01-2008, 00:00
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Remote troubles
I would guess infrared, but with acoustic the problems are pretty much the same because the frequencies are still quite high ... the frequency ranges involved, reflected signals, and interference from other IR sources. I would go with infrared though, can you imagine someone bringing their dog and the room full of conflicting acoustic sources?
With infrared, you have the wavelength of the light ... different infrared sources and detectors operate at different wavelengths, by means of filters/etc.
IR remotes don't just turn on the IR beam, they modulate it with a chosen frequency (say, 10 KHz). The detector circuitry has it's own 10 KHz reference frequency, and rejects IR signals with different modulation frequency.
Unread 07-01-2008, 00:11
steve0o's Avatar
steve0o steve0o is offline
FRC #0195
steve0o will become famous soon enough
Re: Remote troubles
infrared would be better and you could make a transmitter that has only 4 buttons, you don't have to use a television remote.
Camera Troubles cmurdoch Programming 9 11-02-2006 11:34
IR Beam Troubles Goldeye Programming 2 21-01-2006 17:15
MMH Troubles Justin Stiltner Kit & Additional Hardware 3 28-01-2004 16:03
Remote Remote Kickoff for Southern California ChrisH Southern California Regional Robotics Forum 0 05-01-2004 12:36
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
