Go to Post So... the question is this: Does Grady keep his stuffed animals on his Barbie House for playtime, or in his bed to help him go sleepy-pie at night-night time? - Andy Baker [more]
View Poll Results: Best Way to Score
Robot Crossing Lane Marker (Hybrid) 64 35.75%
Robot Crossing Opponents Finish Line (Hybrid) 44 24.58%
Robot crossing Alliance Finish Line 32 17.88%
Trackball Removed From Overpass (Hybrid) 67 37.43%
Trackball crossing Alliance Finish Line under overpass 27 15.08%
Trackball hurdles over overpass 126 70.39%
Trackball on overpass at the end of the match 48 26.82%
Multiple Choice Poll. Voters: 179. You may not vote on this poll
  #31   Spotlight this post!
Unread 06-01-2008, 22:22
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: Best Way to Get Points
Originally Posted by Daniel_LaFleur View Post
With all the traffic out there, I am not so sure this will be at all easy
As long as the bot doing the hurdling stays to one side of the track when actually lifting the ball above the overpass, they should not be obstructed by the opposing alliance. As I understand it, the bump to pass rule is to be used if your bot is blocking travel, but if you are to the extreme side of the lane then supposedly you should not be bothered...
  #32   Spotlight this post!
Unread 06-01-2008, 22:29
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
Originally Posted by nuggetsyl View Post
7 laps with ball 28points
3 over bar 3 laps 30 points
Considering this...it might still be more points if u hurdeled the ball even with regaining control... because its so early...i think we might be overestimating how many times we could go around the track with a ball
Last year for a majority of the matches...u were only able to get 2-3 tubes up and u were lucky if they were in a row...it all came down to the end (atleast during the regionals)
So what if people arnt able to keep control of a ball often enough to go around 7 times... the 3 up and over is sounding good IF you are able to get the ball with it bouncing off walls and on/off robots
Defense is starting to sound like making a clear path for the ball to bounce now instead of keeping the other team from going around...
  #33   Spotlight this post!
Unread 06-01-2008, 22:34
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
7 laps 17 sec a lap no lifting or grabing required no tossing or placing over bar.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
  #34   Spotlight this post!
Unread 06-01-2008, 22:42
AKA: Greg
That 17 seconds, is that estimated? Is there like a certain speed/mobility you used or did yall just run around the track at an estimated speed trying to gain an "about" number... cause that 17 seconds leaves a .058 second for any error...
if that is a really fast robot... then yea that doesnt even account for robots in the way...
  #35   Spotlight this post!
Unread 06-01-2008, 23:03
Mr. A's Avatar
Mr. A Mr. A is offline
Long Live the Fridge
AKA: Mark R Andrews
FRC #3637 (Daleks)
Mr. A has a spectacular aura aboutMr. A has a spectacular aura aboutMr. A has a spectacular aura about
Remember, to get 4 points by moving the ball around the track, you have not be touching the ball when it crosses the line, and regain control after.
Go teams 3637 & 869[/url]
  #36   Spotlight this post!
Unread 06-01-2008, 23:14
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
actually it is a pretty good number..
50 feet is the distance of one entire side.. now you have to cover 2 sides.. So the total distance is 100 feet. And now saying you are going end to end and making also a 10 ft sideways movement each lap that is a total of 120 feet.
An team should be able to average 8 ft/s.
This actual results in a time of 15 secs...
The numbers they used seem to me to be at an average speed of 7ft/s which would result in 17.1 secs for a lap.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
  #37   Spotlight this post!
Unread 06-01-2008, 23:44
Hurdling robots have protection unless there is no clear lane. Admittedly they can get incidental contact still.
  #38   Spotlight this post!
Unread 06-01-2008, 23:49
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
Originally Posted by Neil B View Post
Seeing as you're not really allowed to block (I believe 'interfere' was the word) someone trying to hurdle a trackball, I think that the emphasis will be on hurdling the trackball fast. The most important will be the hybrid mode though. The way I figure, you can get 8 easy points per robot with only dead reckoning, let alone by controlling the robot with a remote.
I do believe that section 6.2.2 of the game manual indicates that your alliance's TRACKBALL is going to be placed randomly in one of three predictable positions on the overpass.
I also do believe that the ROBOCOACH can tell the robot which of the three positions to travel to and knock the TRACKBALL off during the hybrid mode.
I do believe that this method is more accurate than dead reckoning - not saying that dead reckoning wont work - it might score points for the other alliance though
Mitty Robotics Alumni
TKO 1351
  #39   Spotlight this post!
Unread 07-01-2008, 00:52
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
I forsee the best alliance this year being a combo group, with no more than two hurdlers, and the other bots being designed more for lap speed and ball herding. No hurdlers on an alliance seems rather low scoring, but an all hurdler group I think will find they've got a rather worthless lap runner in their non-ball possessing member.
There's only two balls, so if you have two hurdlers on your alliance, the third robot either needs to be running more laps for points, getting in the opposition's way, or helping to rebound balls for the hurdlers.
  #40   Spotlight this post!
Unread 07-01-2008, 01:14
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
Hurdlers will probably be the dominant species in Atlanta. But a few good speedybots would be complementary during both the hybrid and tele periods.
/Jason
  #41   Spotlight this post!
Unread 07-01-2008, 01:44
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
You have to have speders for the hurdlers to score. The trackball has to come around.
  #42   Spotlight this post!
Unread 07-01-2008, 02:41
Bob Steele's Avatar
AKA: Bob Steele
Here is an interesting scenario:
Two robots work together... One passing the ball over the overpass to the alliance partner on the other side and then slipping underneath to wait for that robot to come around and do the same...
This would be like a relay... and the ball would not have to be re-acquired after bouncing... these robots would extend up to pass and then bring the ball back down to travel around the field.
They could also work in pairs using the one without the ball to clear a path for the other as they travel around. Each successful team hurdle would generate 12 points this way...and the ball would never hit the ground. Both robots would get 2 points for making a lap and the 8 for the hurdle.
The hurdle would be legal as the ball would leave the hurdling robot grasp and then touch another robot (the partner robot) allowing the full 6 + 2 scoring.
This would require robots to cooperate... which is a good thing...
Teams may want to start thinking along these lines early in the process.
We will see this in Atlanta... I am certain of that...
If not 2 robots passing directly, certainly myriad other ways of cooperating on the field in one way or another.
It would be wise for teams to consider this type of activity early in their design process.
This is going to be a great year to think about alliances as true teams.
Not just having defined roles which are carried out independently but actually designing to score points together.
We saw our first taste of that last year with the lift points...this year it will be for the entire teleoperated period...
GOOD LUCK TO ALL TEAMS!!
We hope to work with you this year!!!
  #43   Spotlight this post!
Unread 07-01-2008, 04:43
feliks_rosenber's Avatar
feliks_rosenber feliks_rosenber is offline
Félix
AKA: Mentor of Teams #2217 & #2669
FRC #2217 (FOMHA & KY Bots)
feliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the rough
Send a message via MSN to feliks_rosenber
In my opinion the best way to generate points this year will be by defining each team's role and acting accordingly.
Since there are 2 balls and 3 robots, I suppose that 2 robots will be crossing the lines with balls in the possesion and the third team will either help them knock down balls during the hybrid/ put back up on the track in the end or just do as many laps as possible.
I think that the latter option is way better because last year you couldn't score points for just driving fast, this time, however, you can and so teams should benefit from that.
  #44   Spotlight this post!
Unread 07-01-2008, 05:37
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
17 seconds a lap?
Remember:
<G10> Each TRACKBALL that has CROSSED its own FINISH LINE while not in contact with a ROBOT of the same ALLIANCE will earn 2 points. A TRACKBALL that has CROSSED its own FINISH LINE which contacts ROBOTS of both ALLIANCES while CROSSING will earn
2 points.
This means that you will need to release the ball before the finish line and then re aquire it after the finish line. I doubt, very much, with all the traffic and such that that will be an easy task
___________________
- Tennyson, Ulysses
  #45   Spotlight this post!
Unread 07-01-2008, 05:50
Félix
You can grab the ball and have it in possession while making laps.
You don't have to hurdle it although of course hurdling gives more points.
Best way to start Torboticsmember Programming 4 06-02-2007 12:27
Best way to download an entire website sanddrag IT / Communications 6 18-12-2005 00:59
What is the best way for girls to get involved? lalala Chit-Chat 2 15-02-2005 18:31
Best way to make money! SPDEXL Fundraising 17 21-07-2003 01:19
What is the best way to learn? Tton 3D Animation and Competition 7 25-03-2003 19:22
