Go to Post My advice is anytime your intuition tells you something, double check it with physics. - tennispro9911 [more]
Unread 06-01-2008, 21:57
Generator of Entropy
FRC #2973 (The Mad Rockers)
Defensive Strategy - cornering opponents ball
This appears to be legal and a good strategy if you are going up against 2 good hurdlers, or if you have one big slow robot. If you push your opponent's trackball into a corner and "trap" it there, you can prevent them from getting potentially 8 points per lap versus the 2 points per lap you give up sitting there. The definition of herding allows continuous contact, and it doesn't meet the definition of being captured since the ball wouldn't keep the same position relative to your robot if you moved. You aren't impeding traffic so there is no requirement for you to move.
Unread 06-01-2008, 22:01
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
Re: Defensive Strategy - cornering opponents ball
I'm pretty sure they mad the corners like they did to stop the balls from getting trapped in the corner. I'm pretty sure it says that somewhere in the manual
Unread 06-01-2008, 22:06
I agree that the 135 degree corners will make it more difficult to maintain control of the ball then a 90 degree corner, but I think it's still possible. We'll see how well it works if anyone tries it.
Unread 06-01-2008, 22:12
SSMike's Avatar
SSMike SSMike is offline
The Guy with the Big Blue Two
FRC #0250 (The Dynamos)
Team Role: Operator
SSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond repute
What if a robot on the opposing alliance nudges you? If they got in a postition where you were technically impeding them, then you would have to move out of his way and free the trackballs from the corner. This is unless of course the rules specify that you only have to move if you are in the straightaways, which I believe they do not.
Long Live #4
Just when I find the key to success, someone goes and changes all the locks.
"It's kind of fun to do the impossible" -Walt Disney
When you put 'THE' and 'IRS' together, it forms 'THEIRS'. Coincidence? I think not!
Why is the name of the phobia for the fear of long words: hippopotomonstrosesquippedaliophobia?
"There's no such thing as a winnable war......." Bring our Troops Home
I will never let you fall
I'll stand up with you forever
I'll be there for you through it all
Even if saving you sends me to heaven
--The Red Jumpsuit Apparatus
Unread 06-01-2008, 22:32
IbleedPink233's Avatar
IbleedPink233 IbleedPink233 is offline
FRC #0233 (The Pink Team)
IbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to behold
If you are in a corner, then you won't be impeding traffic, unless there are a lot of robots around you.
The rules say that you can herd as many balls as you want, potentially both of your opponents' If you get them both into and inaccessible corner for half the match, then you would be making the game less fun, but you would get a serious advantage.
Unread 06-01-2008, 22:35
AKA: Alan Bartow
Team Role: Driver
I thought the rules said that you could only herd 1 trackball
Unread 06-01-2008, 22:37
The only way I would be technically impeding them is if one of my alliance partners was blocking the rest of the track; there is over 14 feet worth of space between the corner and the lane divider, my robot and the ball will take up 6.5, which leaves enough room for a robot (even 2 robots) to go around me.
Unread 06-01-2008, 22:39
<G27> HERDING TRACKBALLS – ROBOTS may HERD one or more TRACKBALL at one time. ROBOTS shall not HERD a TRACKBALL while also being in POSSESSION of a second TRACKBALL. A PENALTY will be assigned for each infraction.
I hadn't thought of that - trapping both trackballs with one robot. Brilliant!
Unread 06-01-2008, 22:41
If I am not mistaken, you can "herd" as many as you can get your hands on. If you are in "possession" of a ball, then you can't herd any others.
Like I said, I think that ball-hogging will make the game get very old and dry very quickly and I hope that teams find strategies that go along with the spirit of the game instead.
Unread 06-01-2008, 23:42
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
I thought is would be niffty to wait next to your opponents ball until they came into that zone to get it, then hit it into the previous zone, therefore making them go all the way around the field to retrieve their ball.
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
Unread 07-01-2008, 06:33
I believe it is in the spirit of the game is to score more points than your opponent within the rules. That means offense AND defense.
Unread 07-01-2008, 08:26
jrdude's Avatar
jrdude jrdude is offline
Bored? Never...
AKA: Jezumo a.k.a James
FRC #1386 (Trobots)
Team Role: Student
jrdude is just really nicejrdude is just really nicejrdude is just really nicejrdude is just really nice
Send a message via AIM to jrdude Send a message via MSN to jrdude Send a message via Yahoo to jrdude
Smile Re: Defensive Strategy - cornering opponents ball
this seems like a very good idea
Unread 07-01-2008, 08:44
BrianD's Avatar
BrianD BrianD is offline
FRC #2046 (TRC)
BrianD is an unknown quantity at this point
hmm...
Lets say you were cornering the ball. If one or two opposing robots came up beside you, so together you were all blocking the track, could they then bring in another robot and bump you to pass? Might be a counter to this strategy.
It probably be more interesting to simply knock the ball out of the field, but that's unfair to the other team.
Unread 07-01-2008, 09:47
Dolan's Avatar
Dolan Dolan is offline
Dolan
AKA: Andy
FRC #1590 (RAMBOTS)
Dolan will become famous soon enough
Send a message via AIM to Dolan Send a message via MSN to Dolan Send a message via Yahoo to Dolan
you could have one of your team bump them to counter the counter
Originally Posted by BrianD View Post
hmm...
<G40> ....
Note that a ROBOT is not IMPEDING traffic if:
• there is a clear “passing lane” around the ROBOT, or
• the IMPEDING ROBOT and the approaching ROBOT are from the same ALLIANCE (i.e. a ROBOT can not impede another ROBOT of the same ALLIANCE), or
• the ROBOT is in the process of HURDLING (except as noted in Rule <G43>).
My interpretation of this rule is that you are not impeding if the clear passing lane is blocked by the other alliance. They can't simply declare you to be the one who is impeding by bumping you.
Cool defensive strategy.... Salik Syed General Forum 8 06-01-2009 21:41
Can you knock a ball out of a opponents hold... kE7JLM Rules/Strategy 6 20-01-2008 14:25
Ball Collection By Defensive Alliance ewankoff Rules/Strategy 18 11-01-2006 19:21
Defensive Strategy Alex Minot Rules/Strategy 5 09-01-2006 14:12
White Paper Discuss: Simple strategy/couter-strategy sheet CD47-Bot Extra Discussion 2 06-04-2004 22:37
