Go to Post but eventually it seems that we realize that there's an I in FIRST, and the I stands for Inspiration, not for "me" - MrForbes [more]
Unread 06-01-2008, 23:11
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
Re: Problem compiling Kevin Watson's code
Originally Posted by Spencer E. View Post
I have updated my IDE and C18 compiler to 3.10 but when I go to compiler I get this error:
MPLINK 4.1, Linker
Copyright (c) 2006 Microchip Technology Inc.
Error - could not find file 'clib.lib'.
Errors    : 1
The clib.lib file is located in C:\mcc18\lib which is the folder of libraries my IDE is pointing to. Does anyone have any idea what's wrong? I just tried to compile the code without editing it yet.
Nevermind, I fixed the problem, sorry about that guys. You can delete this thread.
Unread 07-01-2008, 00:34
Kevin Watson's Avatar
La Caņada High School
FRC #2429
To fix this problem you need to tell MPLAB where your C libraries are installed (mine are at c:\program files\microchip\mcc18\lib, but yours may be at c:\mcc18\lib). To specify the location select Project > Build Options... > Project > Directories tab > Select Library Search Path> enter the path.
-Kevin
Kevin Watson
http://kevin.org
Trouble using Kevin Watson's Serial Code with Vex user API StargateFan Programming 3 13-01-2007 15:42
Running K. Watson's code on Edubot, BRLOD Mike Programming 5 25-01-2006 20:30
Positioning with Mr. Watson's code Zalumaskov Programming 1 12-02-2005 22:56
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
