Go to Post If it were easy it wouldn't be worth triple the points, right? - SenorZ [more]
Unread 06-01-2008, 23:19
fabalafae's Avatar
fabalafae fabalafae is offline
Guardian of the Grimmerie
FRC #0540 (TALON)
fabalafae is an unknown quantity at this point
Random Allocation of Trackballs
The trackballs are supposed to be randomly assigned positions before the match starts; is it possible, then, to get two balls of the opposing alliance put in front of your alliance? Or are the balls randomly placed so that one red and one blue trackball must be on each side of the track?
Unread 06-01-2008, 23:21
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Lightbulb Re: Random Allocation of Trackballs
As shown in the animation (although some people are questioning the correctness of the animation), the balls were always placed in a red,blue,red,blue configuration.
Hope That Helps!
Tomasz Bania
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 06-01-2008, 23:23
DonRotolo's Avatar
Back to humble
FRC #0832
[EDIT: See below]
Don
Last edited by DonRotolo : 06-01-2008 at 23:41. Reason: Shoulda read the manual...
Unread 06-01-2008, 23:24
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
However, if they are really supposed to be random then I assume that yes, you may get none of your own colored balls on your side, though that seems rather unlikely.
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 06-01-2008, 23:36
<G20> specifies that there will be one of each color on each side.
Unread 06-01-2008, 23:39
fabalafae's Avatar
FRC #0540 (TALON)
Cool, thanks.
I am stricken and can't let you go
When the heart is cold, there's no hope, and we know
That I am crippled by all that you've done
Into the abyss will I run
Unread 06-01-2008, 23:40
DonRotolo's Avatar
Back to humble
FRC #0832
Indeed it does. Hmm, maybe I should read the manual?
<G20> TRACKBALL Locations - After all ROBOTS participating in the MATCH are in their starting positions and the TEAM members are in the ALLIANCE ZONE and/or ROBOCOACH STATIONS, four TRACKBALLS will be placed on the OVERPASS. On each side of the OVERPASS there are three TARGET LOCATIONS for TRACKBALLS. The field management system will randomly choose an initial starting location for the TRACKBALLS before the start of each MATCH. One red and one blue TRACKBALL will then be positioned in the chosen TARGET LOCATIONS on each side of the OVERPASS. After this point in time no ROBOT may be moved or repositioned until the MATCH starts.
Don
Unread 07-01-2008, 09:31
Maggie27's Avatar
Maggie27 Maggie27 is offline
Maggie
AKA: Maggie
FRC #1708 (Natural Selection)
Maggie27 has a spectacular aura aboutMaggie27 has a spectacular aura aboutMaggie27 has a spectacular aura about
Send a message via AIM to Maggie27
I'm pretty sure there will be one red and one blue on each side.
Ordering Trackballs & IR boards Gary Dillard Kit & Additional Hardware 31 01-02-2008 13:00
Trackballs chaineezee General Forum 67 25-01-2008 11:10
Bouncing TrackBalls GBilletdeaux930 Rules/Strategy 22 09-01-2008 22:17
Please help: Memory allocation problem dealing with sections RbtGal1351 Programming 10 14-03-2006 14:58
