Go to Post You miss 100% of the shots you don't take - Steven Donow [more]
Unread 06-01-2008, 23:24
CapnKernel CapnKernel is offline
Parse Error on line: Unknown
FRC #1515 (MorTorq)
CapnKernel has a spectacular aura aboutCapnKernel has a spectacular aura about
Eval() in C?
Is there any possible way of evaluating a string in C? If there isn't, is there a way to call a function with a certain name stored in a string? It seems kind of high-level for C.
Unread 06-01-2008, 23:31
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Re: Eval() in C?
Nope, not in standard C, not without writing your own parser; and I'm sure that's not you wanted.
Maybe if you described the problem in more detail?
Unread 06-01-2008, 23:33
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Eval() in C?
There is nothing like that (converting a string to a function address).
To simulate it, you would compare a variable (perhaps a string variable containing the name of your function) to some constant, then use a switch() statement to call the appropriate function. Example:
int foo( int a, int b)
return a + b;
int bar( int a, int b)
return a - b;
main()
char funcname[] = "foo";
switch (funcname)
case "foo":
foo(a,b);
case "bar":
bar(a,b);
Unread 06-01-2008, 23:34
FRC #1515 (MorTorq)
Re: Eval() in C?
I basically want to be able to store a string in a struct and then be able to call that method when "the time is right." It's almost like Flash's event based structure, so I can't really have separate if statements for every string.
EDIT: mluckham, that'll probably work, thanks.
Unread 06-01-2008, 23:42
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Eval() in C?
Actually, what you're probably looking for is a "function pointer". Structs can store a pointer to a function call that you assign somewhere programmatically in code, and then when you want to call that function you just dereference the pointer (in a specific way). Check it out: http://www.newty.de/fpt/index.html
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 06-01-2008, 23:51
mluckham's Avatar
Re: Eval() in C?
Pretty advanced (function pointers) but they are certainly useful as 'action routine pointers' in a state-action table (look up "Finite State Machine") provided the argument list to all the routines called is identical.
Unread 07-01-2008, 09:45
AndrewN's Avatar
AndrewN AndrewN is offline
it's alive!
AKA: Andrew Nicholson
FRC #1778 (Chill Out)
AndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really nice
Re: Eval() in C?
The way to do this in C is to do the command matching yourself and use function pointers to store a table of the functions you want to use.
The following code compiles with ANSI C. While running it waits for individual characters. If the character matches the command character 'cmd' then it de-references the function pointer, and calls the function. It passes no arguments onto the called function. (Hint: that's an exercise for you).
#include <stdlib.h>
#include <stdio.h>
// Four command functions. They must have identical arguments.
void go_left(void) { printf("Going Left\n"); }
void go_right(void) { printf("Going Right\n"); }
void stop(void) { printf("Stopped\n"); }
void quit(void) { printf("Bye\n"); exit(0); }
// An array of a two value structures.
struct {
    char cmd;			// The character
    void (*function)(void);	// a pointer to a function.
} commands[] = {
    {'l', &go_left},	// put the address of the function
    {'r', &go_right},	// into the function pointer
    {'s', &stop},
    {'q', &quit},
    {0, 0}		// marks the end of the array.
int
main(void) {
    char c; int i;
    while (1) {
        c = getchar();	// not available on FRC
        i = 0;
        while (commands[i].cmd) {
	    if (commands[i].cmd == c) {
		// dereference the pointer and call the function.
                // note the bracketing
		(*(commands[i].function))();
	    i++;
You could obviously extend this to match whole strings instead of characters.
You do not have a "getchar()" function in the FRC code instead you'll have to read a character from one of the serial ports.
The above code is not pretty, badly commented, terse, and follows an arcane indenting style (I'm old).
You should use 'typedef' to define the structure instead of using it inline like this.
The structure is initialized after the command functions have been declared. If the command functions are in another file then you'll have to use 'extern' declarations of the functions before initializing the array.
A sample run:
$ cc ex1.c
$ ./a.out
l
Going Left
r
Going Right
q
Bye
Andrew Nicholson
2011 FRC Robot Inspector (Seattle, Portland)
Mentor FRC 1778 "Chill Out", FTC 3018, 3940 "Hawks", 4434 "Heat Misers"
"Everything should be made as simple as possible, but no simpler."
Unread 07-01-2008, 15:31
FRC #0701 (RoboVikes)
Re: Eval() in C?
The only limitation is that your functions must take the same datatype. If you need them to take different data types you will need to make them all take a single void pointer to a block of memory then the function will need to reconstruct the data itself. This is probably too complicated and you probably won't need it. just throwing it out there if the need comes up
Team 701
Unread 07-01-2008, 15:49
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Eval() in C?
void pointers are evil... in a good way.
it is possible to create an eval function, using some derivative of a reverse polish notation format. however, for the purposes of robotics, it probably wont be worth it.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 09-01-2008, 21:47
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Re: Eval() in C?
Originally Posted by mluckham View Post
main()
switch (funcname)
case "foo":
foo(a,b);
case "bar":
bar(a,b);
Oi... that's going to lead you into a world of trouble.
The C language does not allow for direct comparison of a string, because a string isn't a type, it's a null-terminated array of characters. "foo" is of type const char *, which is an address in your program's memory. funcname is also of type char *, so switch is going to implicitly compare the addresses of the two "strings" and it will never work, because it cannot compare the data at the addresses.
You need to do the following:
if(strcmp(funcname, "foo") == 0) {
    foo(a, b);
}  else if(strcmp(funcname, "bar")) {
   bar(a, b);
Switch only works with strings in PHP and maybe Javascript, as far as I know. You're right though, function pointers are as close to what he's looking for as you can get.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Summer camp program eval. Andrew Schuetze General Forum 3 12-06-2006 22:16
