Go to Post On the other hand, if the tires were marked "NOT FOR FRISBEE SHOOTER USE" I'd be worried. - Ken Streeter [more]
Unread 06-01-2008, 23:51
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
Re: R16 Playing Configuration
Originally Posted by skimoose View Post
The corners are the issue I'm raising. Try sketching out the trackball and the robot's frame and bumpers. Even after accounting for the frame under the balls arc, the back of the robot frame barely stays within an 80" cylinder at the frames corners. So if you're planning to grasp the ball you may exceed this cylinder as you reach around the ball.
my quickie CAD shows that if the ball is tangent to the front plane of your 38"x28" robot, then the front end of the ball will not fit within the 80" cylinder. there are some easy ways to get around this problem, however.
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Dashboard .ini file, configuration bayesianlogic Technical Discussion 1 20-01-2007 17:44
Belt Configuration Hadi379 Technical Discussion 8 10-01-2007 02:57
Configuration File? FFnut Programming 2 03-02-2006 17:38
R06 - weight and configuration jimfortytwo Technical Discussion 6 18-02-2004 08:06
Possible Configuration to keep things cheap archiver 1999 8 23-06-2002 23:03
