Go to Post As Murphy as my witness, things happen and will continue to happen. - Pavan Dave [more]
Unread 06-01-2008, 23:13
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
R16 Playing Configuration
R16 states,
"Once the MATCH has started, the ROBOT may assume a PLAYING CONFIGURATION that exceeds the size dimensions specified in Rule <R11>. While in the PLAYING CONFIGURATION, the ROBOT may expand up to a maximum horizontal dimension of 80 inches (e.g. all parts of the ROBOT must fit within an imaginary 80-inch-diameter upright cylinder). There are no height limits for a ROBOT in its PLAYING CONFIGURATION at any time after the start of the MATCH other than those specified in Rule <G36> about not exceeding the maximum permitted height while in the opponent’s HOME STRETCH."
Last year this rule assumed an cube for max dimension not an upright cylinder. This doesn't leave much room to grasp a 40" diameter ball and lift it. Square robot frames and square end effectors could have problems fitting in this cylinder.
Anyone else see this as an issue?
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 06-01-2008, 23:19
Billfred's Avatar
Billfred Billfred is offline
Re: R16 Playing Configuration
The two statements appear to conflict; it's something for Q&A when it comes online. My hope is that they'd choose the first statement for ease of enforcement (both for us and them).
Unread 06-01-2008, 23:27
DonRotolo's Avatar
Back to humble
FRC #0832
I think they mean that no dimension of the robot can ever exceed 80 inches on a plane parallel to the floor. For a square (or cube) manipulator, the corners are the points that stick out the most, and thus need to be controlled.
I like the idea of an 80" diameter cylinder; in fact I hope they bring a big clear plastic one to the competition so I can get trapped inside it...
Don
Unread 06-01-2008, 23:43
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
Don
The corners are the issue I'm raising. Try sketching out the trackball and the robot's frame and bumpers. Even after accounting for the frame under the balls arc, the back of the robot frame barely stays within an 80" cylinder at the frames corners. So if you're planning to grasp the ball you may exceed this cylinder as you reach around the ball.
Unread 06-01-2008, 23:51
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
my quickie CAD shows that if the ball is tangent to the front plane of your 38"x28" robot, then the front end of the ball will not fit within the 80" cylinder. there are some easy ways to get around this problem, however.
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Unread 07-01-2008, 00:15
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
The BALL does not need to fit into the 80" cylinder, the rule states that the ROBOT must fit into the cylinder...the ball is no more a part of the robot than were the inner tubes last year as far as dimensions are concerned.
Unread 07-01-2008, 00:29
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I believe Art is well aware of that, but is calling out the fact that if you grab the ball at it's center point (equivalent to the Earth's equator line) then you run the risk of going outside the virtual cylinder with your robot.
But there are other ways of grasping the ball, like THIS for example which don't require grabbing it at the Equator line which would work.
This should be clarified by the GDC none-the-less.
Unread 07-01-2008, 00:37
danshaffer's Avatar
Stanford 2012
But as you can see in my quickie CAD, you should still have plenty of room to grab the equator.
That's a 28"x38" robot on the left, a 40" ball on the right and all in an 80" circle/cylinder.
Unread 07-01-2008, 00:39
Billfred's Avatar
Don't forget that you have to wedge some bumpers into that picture. It might not be enough to break the circle, but it's getting closer.
Unread 07-01-2008, 00:56
danshaffer's Avatar
Stanford 2012
Still looks like you have some room to grab at the diameter of the ball...
Unread 07-01-2008, 01:54
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Bumpers don't count towards your robot size for inspection... I'd assume they count here, but who knows?
2001-2004: Team 100
2006-Present: Team 254
Unread 07-01-2008, 09:18
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
They did for the 2007 rules (not for inspection, but during the game).
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Dashboard .ini file, configuration bayesianlogic Technical Discussion 1 20-01-2007 17:44
Belt Configuration Hadi379 Technical Discussion 8 10-01-2007 02:57
Configuration File? FFnut Programming 2 03-02-2006 17:38
R06 - weight and configuration jimfortytwo Technical Discussion 6 18-02-2004 08:06
Possible Configuration to keep things cheap archiver 1999 8 23-06-2002 23:03
