Go to Post We are all on a big team named FIRST - Al Skierkiewicz [more]
Unread 07-01-2008, 00:31
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
Anyone else try pneumatic hurdling?
Anyone else fail miserably?
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 07-01-2008, 00:34
Billfred's Avatar
Billfred Billfred is offline
Re: Anyone else try pneumatic hurdling?
I haven't done much research into what it'll take to hurdle a trackball, so I'll ask: What sort of setup were you using? The approach may make the difference.
Unread 07-01-2008, 00:36
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Yes, we failed miserably, with several bores and strokes. Pneumatic punches alone are most definitely not the complete answer.
GitHub
Unread 07-01-2008, 00:43
BeyondRamo's Avatar
BeyondRamo BeyondRamo is offline
AKA: Omar
FRC #0334 (Tech Engineers)
Team Role: Electrical
BeyondRamo is an unknown quantity at this point
Do we need to actually hurdle the ball over? Can we just move the arm over the Overpass and drop it? Just curious and i haven't heard anything about it.
Unread 07-01-2008, 00:45
330 found that out in 2006... The first designs we tried then were ram-type, and even the pneumatic one didn't work.
Unread 07-01-2008, 00:50
Drwurm's Avatar
Electrical Alumni
We tried many bores and doubled the FIRST allowed air pressure. The best purely vertical height we got was a little over a foot. I think we'll be seeing a lot of bots carrying the ball over, rather than shooting.
Unread 07-01-2008, 00:52
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
No, you would not receive points for this. You can not be in control of the ball as it passes over the line.
Jacob
Unread 07-01-2008, 00:54
Jacob
There is some debate about this--for one thing, the animation disagrees (but that happened several times). For crossing, you are correct. For hurdling, we need clarification.
Unread 07-01-2008, 00:57
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Jacob
The way I read the rules, the "no possessing ball while scoring" rule only applies to the two points for crossing the line, not the six point bonus for hurdling. I could be wrong, but I think you would recieve 6 points for this.
Unread 07-01-2008, 01:03
Billfred's Avatar
Jacob
Here's what I found in the manual:
HURDLE: When a TRACKBALL CROSSES a FINISH LINE while passing above the OVERPASS
and then contacts either the floor or another ROBOT before re-contacting the originating ROBOT.
CROSSING: The act of a TRCKBALL or ROBOT passing through the plane defined by a line (i.e.
LANE MARKER or FINISH LINE) when it is projected vertically upwards. A TRACKBALL or
ROBOT shall have CROSSED a line when all parts of the object, while traveling in a counter-
clockwise direction, have completely passed through the plane.
It appears that your arm placement relative to the finish line is irrelevant when hurdling (as long as you follow the other rules).
Unread 07-01-2008, 01:39
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Kinda like trying to punch a pillow across the room?
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 07-01-2008, 02:21
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
our piston attempt (with our strongest piston mind you) sent our mentors further than the ball, so this probably isnt a great idea.
however, maybe if you held the ball while applying the piston, the released the hold? would the elastic properties of the ball propel it?
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 07-01-2008, 02:24
mbeardsworth mbeardsworth is offline
Lord of the Subversion Repository
AKA: Michael Beardsworth
FRC #2521 (South Eugene High School Robotics)
mbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of light
We're looking into the possibility that a spring might work. Ideally there will be a whole lap to charge it up.
Unread 07-01-2008, 02:39
AdamHeard's Avatar
Lead Mentor
Keep in mind the amount of energy required just to launch the 10 pound ball 6.5' into the air. I don't think that much energy can be safely be released at once on a FIRST robot.
Unread 07-01-2008, 02:43
But maybe for 2-3 ft??
Hurdling akash155 Rules/Strategy 3 05-01-2008 23:50
Anyone try Coca-Cola Blak yet? Elgin Clock Chit-Chat 27 19-06-2006 01:28
pic: Is anyone else scared... WatchinSparxFly Extra Discussion 5 06-04-2005 11:06
Anyone else want a change? Roushey 3D Animation and Competition 19 16-03-2005 00:27
Anyone up for a puzzle? Try Grow... IMDWalrus Chit-Chat 2 27-02-2004 20:39
