Let's swap data!
  #35   Spotlight this post!
Unread 07-01-2008, 00:51
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Trackballs
Also, one more thing should be noted about the balls that is worth some interest.
The zipper head should be under a flap of fabric when you inflate your balls and zip up the outer Red or Blue cover. If it is not, then you did not turn your ball's cover inside out, and put it on correctly.
The ball covers were shipped to you in the "inside-out" position.
Just make sure your zipper is hiding under the flap when it is closed, and you should be golden.
