Go to Post It does it automagically. - David Kelly [more]
Unread 07-01-2008, 01:01
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by SuspectZero View Post
can someone point me in the direction of a tutorial in which i can use this code to program our new 2008 bot? also is there a way of reading the printf statements in an executed program without having to upload onto our robot?
If you take Kevin's simple code and just read it, there's a fair chance you'll be able to do the simple stuff (i.e. left joystick forward = left motor forward) by yourself pretty easily. Reading the aliases in ifi_frc and seeing that the joysticks are referred do as p1_y for the y-axis, for example, and that pwm channels are simply pwm01 through 16 also helps. Where you want to start writing code is the Teleop() function in teleop.c, as that is the function that is called upon receiving data in the teleoperated mode.
As far as prtinf goes, if you place your robot on blocks (so that the wheels are spinning freely and not touching anything) and you keep the programming cable connected to the computer, you will see the results of all printf's in the terminal window that pops up after you're done downloading code usinng IFI Loader.
Hope this helps.
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
