Go to Post In my opinion, leaders do not need to be picked. They naturally emerge as time goes on and as more opportunities are presented to them. - Alex Golec [more]
Unread 06-01-2008, 23:46
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
Re: How many RoboCoach Commands?
Originally Posted by Chrisms View Post
it's not a loophole, just creativity of coding.
also, think about this:
if you had one of your commands "cycle" through a list of 3 other commands, you could have an infinite amount of commands from 4 inputs. however... your robocoach will go nuts trying to figure out which command is which. Maybe if you had a card counter or something.. hmmm.
You could have a few status lights on the robot to tell the robocoach what programming set he had on.
I think that the Robocoach can only make the robot do 4 things during a match. As for the changing from hybrid to tele - the second bullet of <R69> specifically disallows that.
• The ROBOT shall not dynamically change the recognized command set during a MATCH.
If this rule is interpreted literally you would have to have, for example, a button to turn left then a button to stop turning. I believe this rule is intended so teams cannot change code "on-the-fly" during a match (i.e. downloading new code through some remotely operate serial cable). I do not believe this rule prevents cycling through commands like Chrisms and others have stated. Also if your team had PID or traction control and one of your commands was drive straight, then, if interpreted literally, you would have violated this rule (the robot is dynamically changing motor speed depending on the robot's speed).
Unread 07-01-2008, 00:03
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
I believe that it is pretty apparent that the intention of the rules is to only have four commands ever sent to the robot. The GDC went as far as to state this in three separate rules <G01> <R65> and <R69>. I think the best way to interpret this rule is by the 3x5 card where you have to state what the four commands are, if you can write the commands in such a way that there are only 4 commands, i would say it is legal.
for more information i would suggest looking into this topic
http://www.chiefdelphi.com/forums/sh...&highlight=R65
specific rules are listed in my previous post on this matter
http://www.chiefdelphi.com/forums/sh...4&postcount=25
http://www.wcsrobotics.com
team 663
team 1493
Unread 07-01-2008, 00:09
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Multiple IR Key codes to activate four hybrid operating modes
Can we put the lawyers to bed now? I'm pretty sure the intent is FOUR buttons control FOUR commands, in a 1:1 ratio.
I'm mostly interested in figuring out what a "command" is so I can make sure that my students are doing it properly, and so I can explain what they're doing wrong when the issue inevitably arises. I could envision somebody writing this piece of code:
int *fwd[] = {&relay1_fwd, &relay2_fwd, &relay3_fwd, &relay4_fwd, &relay5_fwd};
int *rev[] = {&relay1_rev, &relay2_rev, &relay3_rev, &relay4_rev, &relay5_rev};
int index = 0;
while(true){
  if(button == 1)
    index = (index + 1) % 5;
  if(button == 2){
    *(fwd[index]) = !*(fwd[index]);
    *(rev[index]) = !*(rev[index]);
And their index card reads:
Button 1: Chooses a relay
Button 2: Toggles a relay
So, using two buttons, I am able to turn any of five relays on or off. My command set never changes. I'd call this two commands. I suspect that some people would call it ten, but that seems like a bizarrely strict interpretation, and I'd expect a lot of askance looks from anyone I tried to tell that to. If that is indeed the case, I expect that a lot of teams won't do it properly for a lack of understanding, and that it will be impossible to police.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 07-01-2008, 00:15
[snip]
I should have said actions. The rules say actions as well. (Granted, you've got a point, but I think common sense should win over the lawyers in this case.)
Unread 07-01-2008, 01:14
Vogel648 Vogel648 is offline
Student Programming Leader
FRC #0648 (QC Elite)
Team Role: Student
Vogel648 is on a distinguished road
I was under the impression that this rule was to keep people from choosing which 4 signals to recognize after the match had already started, not it couldn't change it's reaction based on it. So if I were commanding my arm to a specific angle during autonomous it wouldn't be illegal for that to move the arm up sometimes and not others I don't think. But what if I had a + button a - button and 2 toggle mode buttons. The two buttons ALWAYS toggle the mode, the + and the - always effect the mode in the + or - direction... It's really hard to interpret such a rule if you read it as "your robot can only react in 4 different ways to inputs", which is why I think that really can't be.
My 2 cents
-nrv
Unread 07-01-2008, 02:14
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
But the thing is... does it mean physical actions or any action? because you could just map a button to a bit in a 4 bit number, and the remote will not send any encoded messages over nor will it be changing the message set dynamically. granted that would be a beast for the robocoach to control, but still...
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 07-01-2008, 02:24
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
...So, using two buttons, I am able to turn any of five relays on or off. My command set never changes. I'd call this two commands. I suspect that some people would call it ten, but that seems like a bizarrely strict interpretation, and I'd expect a lot of askance looks from anyone I tried to tell that to.
We're looking at that too. Specifically:
A: cycles through positions on the overpass
B: sets position (where our ball is)
C: cycles through starting positions in the home stretch
D: sets starting position
that way the robot will know where it is and where the ball is, and can conduct itself appropriately.
What is the CD opinion on that?
What place are we at? ... TODAI!
Unread 07-01-2008, 02:44
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Why not just have a physical four-position switch on the robot connected to two digital inputs and use those to specify the position of the robot? You'll know it when you place it, and you have the freedom of using the fourth position to do whatever you want.
Unread 07-01-2008, 05:18
JohnC's Avatar
Because almost a year ago now, at PNW 2007, I hung out with one of the mars rover guys (Mark Leon) who told us the exact same story Lavery did (plus lots of other fun stuff ) so I'm inspired to play it how I think they want us to.
We did do something similar to that last year with our various autonomous modes though.
Unread 08-01-2008, 12:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's also harder to do. And, see <R65>:
(emphasis mine)
• use a maximum of four different inputs from the ROBOCOACH (e.g. use four different buttons) during any single MATCH
• communicate no more than four messages, states or conditions to the ROBOT (please refer to Rule <R69> and Rule <G01> for additional information) during any single MATCH.
I'm not quite ready to put it to bed....I see no rule violation (either literal or in spirit) if you transmit 4 different sequences of the four buttons, to execute 4 different high level commands.
For example, using the number buttons,
Drive straight: 241
Turn left: 134
Whack ball: 423
Stop: 123
The signal that the remote sends when you push one button is coded already, somehow, isn't it? I see no rule preventing you from changing the coding scheme.
Might be a Q&A question...with emphasis that the intent of this method is to improve safety by reducing communication errors
Unread 09-01-2008, 00:43
JohnC's Avatar
End of <R65>
  • not use changes in the signal states to encode or transmit larger messages (e.g. Morse code)
Unread 09-01-2008, 01:52
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
Drive straight: 241
Turn left: 134
Whack ball: 423
Stop: 123
You cant say with this method that one button is doing one thing, as they are always part of a larger message.
RPI 2012
BREAKAWAY
Unread 09-01-2008, 08:21
MrForbes's Avatar
AKA: Jim
Not at all! The message is what comes out the other end...and I am still only selecting one of 4 commands, which is what the rules allow.
Note that I specified the message in each case:
For the message "Drive straight", the signal is: 241
For the message "Turn left", the signal is: 134
For the message "Whack ball", the signal is: 423
For the message "Stop", the signal is: 123
I have modified the SIGNAL to be 3 characters, but I have NOT changed the number of MESSAGES. The are still only 4 messages.
To show you what would be illegal, consider this example of a use of a larger number of coded messages, with a smaller signal:
The message "drive" uses a first digit of 1
The message "turn" uses a first digit of 2
The message "manipulate ball" uses a first digit of 3
The message "stop" uses a first digit of 4.
Now, we get to the illegal part:
For a first digit of 1, the second digit of 1 means "slow"
For a first digit of 1, the second digit of 2 means "medium"
For a first digit of 1, the second digit of 3 means "fast"
For a first digit of 2, the second digit of 1 means "right"
For a first digit of 2, the second digit of 2 means "left"
For a first digit of 3, the second digit of 1 means "pop off overpass"
For a first digit of 3, the second digit of 2 means "pick up"
For a first digit of 3, the second digit of 3 means "drop"
For a first digit of 4, the second digit of 1 means "with manipulator down"
For a first digit of 4, the second digit of 2 means "with manipulator up"
See how in this illegal example, we use only the 4 digits, and the signal is only two characters long, but it is decoded into ten different MESSAGES!
Unread 09-01-2008, 08:52
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
R65 states
Active SIGNALING DEVICES shall:
* be operated through only a single input at any given time (e.g. may not be operated by depressing two buttons at one time)
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 09-01-2008, 09:02
MrForbes's Avatar
AKA: Jim
Pressing two buttons in sequence is not the same as pressing two buttons at once.
However, it is likely that the intent of that rule is also to prohibit the longer signal scheme I presented.....so if someone plans to use this scheme, it would be wise to ask about it on the Q&A
Robocoach signals loophole? jacobhurwitz Rules/Strategy 51 29-01-2008 09:16
Too many R/C commands in a loop? ManicMechanic VEX 1 02-07-2007 00:52
How many targets? geeknerd99 Kit & Additional Hardware 19 16-01-2007 18:16
How Many Buttons? Beth Sweet Regional Competitions 13 17-12-2006 21:32
