Go to Post Free time? You mean the time it takes the code to build? - axiomofdarkness [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 21:56
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: If you think that was complicated. try this...
Posted by P.J. Baker.
Engineer on team #177, Bobcat Robotics, from South Windsor High School and International Fuel Cells.
Posted on 9/7/99 5:50 AM MST
In Reply to: If you think that was complicated. try this... posted by Raul on 9/5/99 10:57 PM MST:
Raul,
With a 6 match schedule, I can't quite agree that won lost record should be the most important factor in seeding. I do think though, that this year it was not important enough. It probably was possible for a 2-6 team to seed ahead of a 6-0 team. That's not right.
I'm perfectly comfortable with a 5-1 team, or even maybe a 4-2 team seeding ahead of a 6-0 team. A team that should have been 4-2 is just as likely to get 2 lucky wins and go to 6-0 as a team that should have been 6-0 is to get 2 unlucky losses and slip to 4-2.
This is why I think that it is important to also look at the scoring and defensive capabilities of the team. If we played lots more matches, I'd be with you 100%. With only 6 though, I think that the seeding should be based on as many measureable factors as possible (won/loss, ave. offense, ave. defense). What do you think?
P.J.
[IMG] code is Off
Championship Seeding Mike Martus Championship Event 18 26-07-2003 12:34
VCU low seeding matches... archiver 2001 14 24-06-2002 02:03
Possible seeding problem at regionals archiver 2001 10 23-06-2002 22:25
Great Lakes Regional Seeding Scores are up ... (EOM) archiver 1999 4 23-06-2002 22:12
Possible Rule change for Flordia? (Please) and the reason for more seeding rounds. archiver 1999 6 23-06-2002 22:09
