Go to Post If we succeed, we succeed as a team if we fail, we fail as a team but either way, we are a team - we go home together and celebrate our accomplishments, whatever they are and try to learn from our mistakes. - KenWittlief [more]
Unread 07-01-2008, 08:59
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
Question Multi-Speed Gearboxes
How long before a team puts an 8 speed gearbox on their robot, or has it already happened?
Design. Build. Dew.
Unread 10-01-2008, 00:36
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Multi-Speed Gearboxes
8 speeds is little excessive. i would say that 2 or 3 is the most you would find on an FRC bot. maybe 4 but that is rare.
-vivek
"we don't build robots, we build people"
Unread 10-01-2008, 00:58
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Two-speeds are pretty common (e.g. SuperShifter, many custom ones), and three-speeds are found occasionally (e.g. Tigertrons' ball shifter, DeWalt transmission), but four-speeds are rare (e.g. Killer Bees' transmission). I don't know of any with more ratios than that, except if we count CVTs (e.g. WPI's toroidal CVT).
As you increase the number of discrete ratios, you risk spending too much time shifting (with your wheels are disengaged), and not enough time driving. Also, most shifting mechanisms use either servos, which are relatively weak, and tend to be slow, or pneumatic pistons, which are fast and strong, but very bulky and generally only useful in two positions. As you increase the number of mechanisms that need to be shifted, you risk increasing the complexity to unreasonable levels.
Typical design and usage of a FIRST transmission involves one low ratio for pushing other robots, and another high ratio for driving. While it's possible to have other ratios, there is rarely a need for full power at medium speed, and consequently you can just ease off on the throttle if high gear is too fast for sufficient maneouvrability.
Unread 10-01-2008, 01:33
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
In my experiences, two is plenty. One high torque, the other high speed. Eight is too much for the driver to think about, and the problem of sifting comes, it is far to complected and useless, but if you planning of hitting highway speeds around the track, that might not be such a bad idea. Good Luck on that though..... Now that I think of it, Does FIRST have a rule limiting the speed of your robot?
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
pic: 1276's 2007 3-Speed AM Gearboxes Ian Curtis Extra Discussion 10 06-03-2007 17:02
pic: Team 948 2-Speed Gearboxes jfelser Technical Discussion 10 08-02-2007 23:26
Multi-Speed motor Questions Burg Robotics Education and Curriculum 2 23-12-2004 15:54
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
