Go to Post I was very concerned about this thread. Then I realized you were talking about a computer. - Taylor [more]
Unread 07-01-2008, 03:59
Robo_Coyote's Avatar
Robo_Coyote Robo_Coyote is offline
Cheap_Shot
AKA: Chris Chandler
FRC #1323 (MadTown Robotics )
Robo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to behold
rule question on scoring above overpass
my idea is that it would be fast when trying to score, to place the ball on the overpass, then drive under and retrieve it from the top of the overpass. I think this will be easier than trying to track the bouncing ball back down. Does anyone see anything questionable about this rule wise?
2005- Uc Davis Spirit Award
2006 nationals second highest score thanks to 233, and 1184
We need a longer highlight list....... sigh
"To invent all you need is imagination and a pile of junk" - Thomas Edison
Unread 07-01-2008, 04:27
Billfred's Avatar
Billfred Billfred is online now
Re: rule question on scoring above overpass
From the manual (which is quality reading, lemme tell you), emphasis mine:
HURDLE: When a TRACKBALL CROSSES a FINISH LINE while passing above the OVERPASS
and then contacts either the floor or another ROBOT before re-contacting the originating ROBOT.
Unread 07-01-2008, 04:29
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Originally Posted by Billfred View Post
I suppose it would help you a bit if the action you described was an allowable form of hurdling. From the manual (which is quality reading, lemme tell you), emphasis mine:
Thanks Billfred. I had heard a rule about touching the Trackball existed, and was reading up on it, but couldn't find it.
Thanks for that manual quote.
Unread 07-01-2008, 07:01
GaryVoshol's Avatar
Cogito ergo arbitro
But, while the trackball is sitting on the overpass it hasn't yet CROSSED. So is the second-touch rule in effect yet?
(since 2004)
Unread 07-01-2008, 08:55
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Originally Posted by <G22>
Direction Of Traffic – ROBOTS must proceed around the TRACK in a counter-clockwise direction. Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction. A PENALTY will be assigned for each infraction.
You also run into rule G22. If you reach back to grab the ball, you'll be crossing the line in the clockwise direction.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 07-01-2008, 09:09
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
this is very tricky.
because your trackball is now resting on the overpass, part of the ball extends past the finish line. if you now dislodge the ball, using your robot then you get no points, since you are touching the ball while it is crossing the line.
you get no 2-point score nor the 6-point bonus. however, if you pull the ball back from the overpass, and then hurdle the ball correctly, the score should be given.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 07-01-2008, 09:16
GaryVoshol's Avatar
Cogito ergo arbitro
jerry w
And that's another question. Does the rule prohibiting touching the ball as it crosses the line apply to hurdling?
(since 2004)
Unread 07-01-2008, 09:22
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
I believe you are allowed to be touching the ball during hurdling. I also believe that will a clarifying update from FIRST explaining this. Lots of threads on this site asking the same question.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 07-01-2008, 09:37
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I do not believe that you will score if you are touching the ball while hurdling. The reason is that 2 points are scored because the ball passes the line with a 6 point bonus for being over the bar. Since the ball was being touched while crossing the line, there would be no point for crossing the line and and as such no bonus points either.
___________________
- Tennyson, Ulysses
Unread 07-01-2008, 09:44
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
Yea Dan,
I saw your post and reasoning on other threads. I guess only time will tell who is right
I believe your logic is correct for going under BUT not for going over.
If I knew that I would see you in Atlanta I'd put a friendly wager on it
Unread 07-01-2008, 09:57
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
um you can definitely work around that just make you manipulator work above your robot
i.e. put the ball on the over pass
and move foward ( cross the line for two points yessssss!!!!!!!! more points) and reach back w/o moving your entire robot back
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 07-01-2008, 10:18
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
So at what point do you actually have to release the ball?
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 07-01-2008, 11:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I suspect you are doing gyrations that are not necessary. As someone else said, we need clarification from First.
1. Can you touch the ball while hurdling it through the start/finish plane
2. Can you break the plane from the non-home stretch side of the field with your gripper to knock the ball off in hybrid
Unread 07-01-2008, 11:13
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Yea Dan,
hehe.
If we make it to Atlanta (we'd need to win the BAE GSR) I'll take that friendly wager ... say a box of Krispy Kremes? (**Hey Dave, I'd split 'em with you **)
___________________
- Tennyson, Ulysses
Unread 07-01-2008, 12:25
tbd tbd is offline
FRC #1577
tbd is on a distinguished road
We have a simmilar dilemma:
What actually is considered a hurdle?
^ is that really a possibility? Is putting the trackball on the overpass and just pushing it off again considered a hurdle? Can the ball even touch the overpass when its hurdled?
And then ofcourse can you touch the ball during the hurdling?
Question on rule S03 colt527 Rules/Strategy 2 10-01-2006 20:18
pic: Galileo from above...WAY above! CD47-Bot Extra Discussion 8 21-04-2004 14:22
Rule M7 Question Stephen Kowski General Forum 2 13-02-2003 14:00
RULE Question. archiver 2001 7 24-06-2002 00:38
rule question.... archiver 2001 1 23-06-2002 22:54
