Go to Post I want to help them to get what's made such a difference to me... - Beth Sweet [more]
Unread 07-01-2008, 09:16
GaryVoshol's Avatar
Cogito ergo arbitro
Re: rule question on scoring above overpass
Originally Posted by jerry w View Post
this is very tricky.
because your trackball is now resting on the overpass, part of the ball extends past the finish line. if you now dislodge the ball, using your robot then you get no points, since you are touching the ball while it is crossing the line.
you get no 2-point score nor the 6-point bonus. however, if you pull the ball back from the overpass, and then hurdle the ball correctly, the score should be given.
jerry w
And that's another question. Does the rule prohibiting touching the ball as it crosses the line apply to hurdling?
(since 2004)
Unread 07-01-2008, 09:22
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
I believe you are allowed to be touching the ball during hurdling. I also believe that will a clarifying update from FIRST explaining this. Lots of threads on this site asking the same question.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 07-01-2008, 09:37
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I do not believe that you will score if you are touching the ball while hurdling. The reason is that 2 points are scored because the ball passes the line with a 6 point bonus for being over the bar. Since the ball was being touched while crossing the line, there would be no point for crossing the line and and as such no bonus points either.
___________________
- Tennyson, Ulysses
Unread 07-01-2008, 09:44
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
Yea Dan,
I saw your post and reasoning on other threads. I guess only time will tell who is right
I believe your logic is correct for going under BUT not for going over.
If I knew that I would see you in Atlanta I'd put a friendly wager on it
Unread 07-01-2008, 11:13
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Yea Dan,
hehe.
If we make it to Atlanta (we'd need to win the BAE GSR) I'll take that friendly wager ... say a box of Krispy Kremes? (**Hey Dave, I'd split 'em with you **)
___________________
- Tennyson, Ulysses
Unread 07-01-2008, 17:30
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
Originally Posted by Daniel_LaFleur View Post
hehe.
You've got it Dan Let's monitor this thread to see who was right
Unread 07-01-2008, 18:17
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
Hey Dan!
This just in from FIRST and the very FIRST Team Update.......
Section 7 – The Game
Section 7 – The Game has been updated as follows: Rule <G36> has been removed. There is no longer a height restriction in an
opponent’s homestretch. The reference to Rule <G10> has been deleted from Rule <G11>. Robot contact with a trackball while hurdling is permitted, however a trackball passing under the Overpass and across the finish line must not be in contact with a Robot, per Rule <G10>.
I like chocolate Krispy Kremes
Unread 07-01-2008, 18:55
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Hey Dan!
Chocolate Krispy Kremes it is ... Now to make it to Atlanta.
___________________
- Tennyson, Ulysses
Unread 07-01-2008, 18:58
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
HURDLE: When a TRACKBALL CROSSES a FINISH LINE while passing above the OVERPASS and then contacts either the floor or another ROBOT before re-contacting the originating ROBOT.
Deleting the Ref. to R10 from R11 means you can stay in contact with the ball while hurdling. Looking at the definition of Hurdle am I right to state the following:
The definition says to be a hurdle, the trackball must contact the floor or another robot before re-contacting the originating robot, you still have to let go of the trackball before, during or after the trackball completely crosses the plane of the finish line to count, it is just that now you do not have to be concerned about when you let it go (penalty/point wise). EDIT: you can not have the trackball completely pass the finish line, pull it back into you home stretch, drop the ball on the floor and quickly regain control, provided your robot doesn't completely enter the next quad.
And I have another question:
Lets say that my trackball passes my opponents finish line and somehow or another moves clockwise back into the quad between the home stretches, as long as I do not break the plane of the finish line, can I hurdle in a cockwise direction and then say have an alliance partner place the trackball on the overpass from my home stretch?
Unread 07-01-2008, 19:05
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
I believe that the spirit of the rule indicates that your first scenario is correct.
In your second scenerio ....... ya' you can do it but without getting points so why bother. Of course, you'd get the points at the end of the match if that is your intent ......... hmmmmm more checking needs to be done
Unread 07-01-2008, 19:31
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Do the rules indicate if the scored trak ball (either under or over) cannot be scored again, prior to going around again?
I don't recall reading that - and the way the balls bounce around, it might be difficult to remember if a ball had bounced clockwise - (opposite direction, backwards into the neighboring quadrant) -after it had previously scored.
If it is okay to pick up and score a trak ball that has bounced backwards - It would increase the opportunity for higher scores.
I guess I'd better start re-reading those parts of the rules one more time.
Unread 07-01-2008, 20:37
jediptm jediptm is offline
AKA: Pete Mueller
FRC #1701 (RoboCubs)
jediptm is an unknown quantity at this point
Here is the relevant portion of the rules...
<G12> A TRACKBALL must CROSS a LANE MARKER before it can score for the first time by HURDLING or CROSSING its FINISH LINE.
<G13> A TRACKBALL that has CROSSED its own FINISH LINE must CROSS the opponent’s FINISH LINE before it can score by CROSSING its own FINISH LINE again.
Another question, does hurdling count as "crossing its finish line" in this instance? It seems that crossing and hurdling are considered two separate actions. If this is true, can you have a robot just past your finish line bump the trackball back to your hurdler and have them re-hurdle the ball? (assuming neither robot crosses the finish line)
Unread 07-01-2008, 23:46
volunteer helper
FRC #6099 (Knights)
Thanks jediptm for the clarification of G13
We have given some thought to the track ball passing over the overpass and believe that making contact with the overpass (actually rolling over it) is okay - as long as the ball continues to move forward once it brakes the plane of the finish line.
If the ball should not continue forward and instead come to rest in one of the openings - it would no longer be considered as passing over the over pass - and subsequently not get the points associated with hurdling.
It might however still qualify for the 12 points at the end of the match.
I'm sure the question will be asked on the FIRST site soon - and then we'll know for sure.
Mike
Unread 07-01-2008, 18:41
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
hehe.
I will be waiting for my half-dozen in Atlanta...
-dave
Unread 07-01-2008, 18:48
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
-dave
I'll be happy to share my bounty with you Dave. It'll be a privilege
Question on rule S03 colt527 Rules/Strategy 2 10-01-2006 20:18
pic: Galileo from above...WAY above! CD47-Bot Extra Discussion 8 21-04-2004 14:22
Rule M7 Question Stephen Kowski General Forum 2 13-02-2003 14:00
RULE Question. archiver 2001 7 24-06-2002 00:38
rule question.... archiver 2001 1 23-06-2002 22:54
