Re: 2008 Default Code?
Yes, I know that it is the same as 2007 and I do have a copy of that and I know where to get it from IFIRobotics. So I don't really have a problem. My question is did the Default code come with the KOP? I'm wondering this because I couldn't find it there and new teams might be confused.
I don't believe it is included in the KOP. In fact, I don't recall it being in there for at least four years. (I have only been here four years, so I can't comment on years prior to that.) I believe using the 2007 Default Code will be just fine, but if someone knows otherwise, please speak up.
Hi I've looked all over the FIRSt site but I can't find the actual code. can someone help me?
You should go to http://www.ifirobotics.com/ (actual default code) or http://kevin.org/frc/ (default code with more sensor support and a new default code with a better structure)
Thank you very much!!!!
| Problems integrating CMUCAM code and IFI Default Code | Windward | Programming | 2 | 06-02-2007 16:48 |
| Modified default code gives "code violation" | scottmso | Programming | 8 | 10-02-2006 23:17 |
| problems using gyro/adc code with camera default code | tanstaafl | Programming | 7 | 22-01-2006 23:09 |
| user code to default code | phoenixomega001 | Programming | 5 | 09-01-2005 00:09 |
| Inserting Naviagation code into Default code? | actorindp | Programming | 3 | 28-01-2004 18:12 |
