Kit Gear Tooth Sensor, rotation and where to get more
Can it be used as an encoder to tell the rotation of the gear it's mounted for? Also these seem to be what FIRST has given us. However the image doesn't seem to show what we actually have. Is that exactly what FIRST gave us or would we need something else.
Re: Kit Gear Tooth Sensor, rotation and where to get more
So from counting teeth we could derive the # of rotations? We should already know the direction from what we are telling the robot to do?
Thank you for the help. Anyone know if the link in my first post is the sensor that they gave us? |
You don't necessarily know the direction that the motor is spinning. As a first approximation, you do, but when you are reversing direction, or being pushed, you can be applying power to have the motor go one direction and actually have the wheels, and therefore your encoders, be spinning in the other direction.
| Gear Tooth Sensor | Nathan | Programming | 4 | 12-01-2008 15:09 |
| Gear Tooth Sensor? | Raikon | Kit & Additional Hardware | 3 | 09-02-2007 16:40 |
| dumb question: Where do we get the gear tooth sensors from? | waialua359 | Programming | 6 | 30-01-2007 22:45 |
| Gear Tooth Sensor | nukem | Programming | 9 | 04-02-2006 20:21 |
| Gear Tooth Sensor | AMIRAM | Electrical | 2 | 22-01-2006 04:09 |
