Re: G27
the rule book also specifies that bulldozing is legal
Rule <G28> says "Inadvertant bulldozing of trackballs while the robot moves around the track is allowed whether or not the robot is in possesion of, or herding, a trackball" so to answer your question, no, it is not going to be penalized unless the trackball is being continually bulldozed therefore being defined as herding. |
Re: G27
Re: G27
but wouldn't that be considered herding since its trackball to trackball contact?
Re: G27
But you can't herd while you have another ball in your possession.
Re: G27
It looked to me that the initial question was about bulldozing a ball. When you bulldoze game pieces, you may or may not be trying to hit them. As long as you did not continue after the trackball you bulldozed or go out of your way to bulldoze it in the first place, I believe that the referees would not give you a penalty as they would see that your objective was not to herd a trackball while possessing another. |
Re: G27
So, the idea of using a possessed Trackball to push up on a Trackball in the oppossing alliances overpass is no longer needed! Thank goodness for Unpdate #1.
#7
Re: G27
In 2004, a large ball possessed by a robot counted as part of the robot. Under that rule, I believe using a track ball in your possession to knock another track ball off an overpass would be a rule violation. I don't see any such rule in this year's manual, but that doesn't mean it won't be there. I suspect that the status of such a ball will be clearly defined by an update.
As a side note, I like to think the 2004 rule was put in place because of something my former team (177) did at the 2001 Hartford Regional. Our robot had one of the big balls in its claw when it fell across the field barrier. The robot landed such that the ball was between the top of it and the floor outside of the field. After about five minutes of searching through the rule book, the refs couldn't find anything about such a situations, and the robot was ruled to be in bounds. |
#8
Re: G27
-dave |
#9
Re: G27
I didn't mean to assume that the rule from 2004 would apply this year. I only meant to point out that a specific rule about the definition of a ball possessed by a robot had existed in past years, and would probably exist again. I didn't mean to imply how the rule would define it.
#10
Re: G27
Jake -
Don't sweat it. The post was not specifically targeted at you. Your message just provided the convenient catalyst that was needed to bring up the "don't rely upon previous game rules for this year's game" topic, which does need to be refreshed in people's memory every year. -dave |
