Go to Post My code mentors once told me, "A good programmer can look at a library, decide he hates it, and code everything from scratch. An amazing programmer can look at a library, decide he hates it, but realize the time it will save him and learn to use it." - slavik262 [more]
Unread 07-01-2008, 11:16
Evert Evert is offline
FRC #2185
Evert is an unknown quantity at this point
Height of overpass
I can't find the exact height of the overpass. I've checked the Arena Manual but can't find anything.
Any help would be appreciated
Unread 07-01-2008, 11:21
Nate Laverdure's Avatar
FRC #2363
Re: Height of overpass
As per Section 6 of the manual, page 6:
The horizontal portion of the OVERPASS is 6-1/2 feet above the floor.
Unread 07-01-2008, 11:22
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
6.2.2 The OVERPASS
Unread 07-01-2008, 11:25
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Pages 5 & 6 of The Arena.
Unread 07-01-2008, 11:27
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Is this the bottom, middle, or top of the overpass rail that's 6.5' from the floor?
GitHub
Unread 07-01-2008, 11:32
fabalafae's Avatar
fabalafae fabalafae is offline
Guardian of the Grimmerie
FRC #0540 (TALON)
fabalafae is an unknown quantity at this point
The top rail where the trackballs sit is 6.5' from the floor.
I am stricken and can't let you go
When the heart is cold, there's no hope, and we know
That I am crippled by all that you've done
Into the abyss will I run
I knew that question was next for some reason. lol
Looking at the multiple CAD drawings here may give you a more exact point that the 6.5' mark is.
http://www.usfirst.org/community/frc...t.aspx?id=7684
I haven't had time to look at them in depth, but probably will in a little bit, and then I'll try and come up with a better answer as I CAD everything out.
Unread 07-01-2008, 12:40
IndySam's Avatar
I would advise against planning for an exact height. You should always plan for the specs to be a little off.
The fields usually don't maintain the exact specs for many reasons, damage, settling, changes to ease construction, sagging.....
Plan for it to be the correct but be prepared for it to be a bit off.
Unread 07-01-2008, 14:11
FIRST explicitly says to expect changes of up to 1/4". This is due to different crews setting the thing up. (Trust me, it's harder to set up a field than it sounds.)
rule question on scoring above overpass Robo_Coyote Rules/Strategy 35 08-01-2008 09:03
pic: Dimensions of the Trackball on the Overpass Bethany Mc. Extra Discussion 2 07-01-2008 09:01
Height of basket Max Brin Technical Discussion 1 12-01-2006 14:43
Bar Height Paul H Rules/Strategy 3 10-01-2004 19:28
Bar Height DuDaKyD General Forum 11 09-01-2003 22:54
