Go to Post Make sure what you are using is polycarbonate and not acrylic or it may very well literally shatter your dreams. - cadandcookies [more]
Unread 07-01-2008, 11:21
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Track balls off the overpass in Hybrid mode- who scores?
Sorry if this has been addressed elsewhere in the forum- there seems to be a wide spread discussion on all issues in more than one thread...
I read in the rules that in Hybrid mode you get 8 points for each ball that you remove from the overhead rack, does this apply to a ball of either color or does the alliance that matches the ball color get the 8 points regardless of who knocks it off the overpass?
Thanks
Unread 07-01-2008, 11:24
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Track balls off the overpass in Hybrid mode- who scores?
7.3.3
<G03>
All TRACKBALL scores are awarded to the ALLIANCE associated with the scored TRACKBALL, independent of the ROBOT that may have caused the scoring action to occur.
Recognizing the colors of the balls in autonomous mode Armando Gonzalez General Forum 13 05-01-2008 22:35
Who Has Scored on The Other Side of the rack in Autonomous Mode E. Wood General Forum 5 20-05-2007 23:11
Cmucam + track color + auto servo mode kheops1982 Programming 5 09-04-2006 13:32
Best way to collect balls [off the field]? DonRotolo Technical Discussion 46 14-01-2006 15:15
