Go to Post "C'mon Amanda, this is eating doughnuts, not rocket science." "[Dave Lavery's] better than me at both!" - Amanda Morrison [more]
Unread 07-01-2008, 12:17
masterkoppa masterkoppa is offline
AKA: Andres Ruiz
FRC #1872 (Yellow Fever)
masterkoppa is an unknown quantity at this point
Send a message via MSN to masterkoppa
Number of Pneumatic Pistons
I would like to know the maximum amount of pneumatic pistons you can use in 2008.
Team 1872 (Yellow Fever)
Programer
Unread 07-01-2008, 12:38
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Number of Pneumatic Pistons
Check out section 8 of the manual...
<R89> In addition to the pneumatic cylinders provided in the Kit Of Parts and the “free” pneumatic
cylinders available for order through the Free Pneumatic Components Order Form,
additional air cylinders or rotary actuators may be used. All cylinders, regardless of source,
must be identical to those listed on the Free Pneumatic Components Order Form (e.g. same
part numbers). Any additional air cylinders must source from Bimba or Parker Hannifin, or
be recovered from prior year FIRST Kit Of Parts.
Unread 07-01-2008, 12:39
Nate Laverdure's Avatar
FRC #2363
Unlimited, as per R89, posted above. However, you can only get three for free, as per the 2008 Pneumatics Manual, page 6:
Quantities of no charge custom cylinders will be limited to 3 per team. Additional cylinders can also be purchased through a Bimba or Parker-Hannifin Distributor.
Unread 07-01-2008, 18:29
etphonehome etphonehome is offline
FRC #0537
etphonehome is an unknown quantity at this point
you can have as many pistons as you want
but if you use too many, your compressor will have to run continuously to keep the circuit charged
remember you only have 4 storage tanks
Unread 08-01-2008, 12:59
AKA: Andres Ruiz
Thanks for the quote from the rule book cause i understood that you could only use 3 of them. Thank you for your help.
Programer
Pistons or Spurs? JoeXIII'007 Chit-Chat 63 24-06-2005 15:57
pic: 830 teaser # 3 Pneumatic Pistons Karthik1 Extra Discussion 12 12-04-2005 20:05
PSI formula for pneumatic pistons Ryan Pneumatics 10 13-01-2004 12:56
Spring-Loaded Pistons TwoEdge47 Rules/Strategy 2 30-01-2003 21:36
Custom Pneumatic Pistons, Cut off date? Jordan A. Pneumatics 2 29-01-2002 21:15
