Go to Post i just want to say how awesome the high volume tank is. The high volume tank is 7/4 as awesome as the previous tanks. - Tytus Gerrish [more]
Unread 07-01-2008, 14:35
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Suggestion to Fix Rules of Height, and Opposite TrackBall
I think one good way to fix the rules of the height, and getting your own ball down from Opposing side, would be to put both the SAME colored trackballs in your Alliance side.
So instead of a RED and BLUE trackball, you get two RED trackballs (Red Alliance) and two BLUE trackballs (Blue Alliance) in front of you. That would fix it up pretty nice and allow your alliance to get 16 points in hybrid if both of you can get a ball down. What do you guys think? I am sure the game design guys have their own idea, but that would be a pretty sweet change up.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 07-01-2008, 14:42
Re: Suggestion to Fix Rules of Height, and Opposite TrackBall
Who says they need to be fixed? I wouldn't be upset if the rules remained exactly as they are. I can think of five ways to remove a trackball from the overpass above the opposing alliance's lane while not violating any rules.
Unread 07-01-2008, 14:54
Controls Engineer
AKA: chakorules
This is TRUE, however I was trying to inject "positive" thoughts into CD.
I can't remember where I read it, but someone pointed out that no score was shown in the animation this year. I am starting to believe, this MIGHT be a planned task. In that yes, they GDC meant to do this. What was it that Dave said was "Albert Einstein Quote"???
BTY....seen you on NASA TV :-) You looked as serious as you always do. :-)
Favorite CD quote:
Unread 07-01-2008, 14:58
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I don't think that FIRST needs to change the positioning of the balls. BUT I do think I will see them change the 6' rule on the opposing home stretch. That said...
Would you like to share any of your ideas??
Also I saw you on the webcast too! How did you get such good seats?
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 07-01-2008, 15:05
Controls Engineer
AKA: chakorules
1. Cross the Finish Line, and reach backwards to get your ball.
2. Use another ball.
3. We are checking this one..field not done yet...but over pass is 6.5, ball droops down into the 6.0 feet range, 7" droop maybe??? you might be able to stick up right at the 6 feet mark, and still barely scrap the bottom of the trackball from bottom....again...still checking into that one...
that's a couple.
Favorite CD quote:
Unread 07-01-2008, 15:27
Bob Steele's Avatar
AKA: Bob Steele
I agree that something needs to happen. I personally like the idea of the balls being in the scoring pass but there is a problem with that. The opposing team would not be able to descore them at the end... so a team with no hurdlers could get an automatic 24 points...just leave the balls there...
this would negate 3 hurdles from the other team... and then its a pure race...
You "might" be able to kick a ball out of someone's home zone overpass from underneath but that will be a nightmare for the referees.
If the rule actually means that if you reach "back" into the zone you are violating the six foot rule I see no good way for a robot to dislodge a ball from the opponents home zone. Crossing the plane of the zone would be considered "in" the zone therefore illegal. If one cannot contact the ball (it is at close to 6 feet) from either inside the zone or outside the zone the only alternative is to use the ball to do the removal. That will NOT happen in Hybrid...
Let's all wait and see what the GDC (Q and A) decide to say about this.
Other alternatives are:
No 6 foot rule during Hybrid....
Referees bump all balls down at the close of hybrid....
reaching back to bump a ball out is not considered an infringement of the 6 foot rule...
6 foot rule only applies from INSIDE the zone...
We shall see... I would expect this to be addressed pretty quickly...
perhaps even in the first update...
Unread 07-01-2008, 15:46
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Not legal. Look at the Finish line position, you have to break the plane to knock the ball down. Even if you don't cross the plane because of ball overhang what is the chance you won't get penalized for it, I already see shades of the 2005 touching the loading zone triangle penalty controversies.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 07-01-2008, 15:53
Chris got three of them. The other two are something I'd actually like to keep as team secrets for now, sorry. If we don't decide to use them, I'll put them in the public domain.
The mentor and student representatives of President's Circle teams were invited to attend the Kickoff (and the Founder's Reception) as VIPs.
Unread 07-01-2008, 16:05
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
I would agree with Alan Anderson, nothing really needs to be changed, there are several easy ways to do it without violating the rules as they are and I am a, the rules are what they are kind of guy and you should leave them alone unless a huge saftely overlook, or a contradiction or something that makes doing a task impossible or other similar situation arises before you change them. In this case you can make it work, you may just have to sacrifice some other task to do it.
However, if rule changes are in order, I agree with Bob Steele, Refs take them all down at the end of Hybrid and it is just a matter of deciding where to put them.
Unread 07-01-2008, 16:17
GaryVoshol's Avatar
Cogito ergo arbitro
Likely 10-point penalty for reaching backward across the line. There's only about 4" of legal ball surface to contact that is across the finish line.
Doesn't appear to be legal per <G27> - it would be herding while in possession of another ball.
I'm doubtful the droop will be enough to use any mechanism on your bot that stays under 6 feet. If a team can do it, all power to them.
Hopefully they will turn out to be good outside-the-box thinking.
Use the 2006 Pokey-pokey sticks, and let them fall where they may?
(since 2004)
Unread 07-01-2008, 16:41
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
anyone thinking flags?
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Unread 07-01-2008, 16:50
ALIBI's Avatar
FRC #0141
Team Role: Parent
Per Gary V. "Doesn't appear to be legal per <G27> - it would be herding while in possession of another ball."
Per Definitions: HERDING: Controlling the position and movement of a TRACKBALL while the TRACKBALL is not supported by any ROBOT (i.e. supported by the TRACK or other TRACKBALLS) shall beconsidered HERDING. Both continuous and intermittent contact between the ROBOT and
TRACKBALL are permissible methods of HERDING. E.g. bumping, plowing or dribbling a TRACKBALL around the TRACK are all considered forms of HERDING.
I am still debating this one. "Controlling the position and movement" Hiting a trackball with another trackball (in your possession), my question about this is whether or not I could really have any control over where the hit trackball would end up, no doubt I would be causing the trackball to move from a resting position, this makes me think I should agree with the conclusion quoted. "Both continuous and intermitant contact" makes me think you have to hit it at least twice to be considered herding and that one hit would be OK.
How about number four try for legal means: why not catapult a trackball from your less than six foot high robot, at most it would be considered herding?
Unread 07-01-2008, 17:43
lopz056's Avatar
lopz056 lopz056 is offline
Chris Lopez
AKA: chris lopez
FRC #1388 (Eagle Robotics)
lopz056 is an unknown quantity at this point
yeah i think that was a good idea because i noticed that in the animation and in the real life imitation of the game they broke the hight requirements of the opposing home stretch zone, so ive been wondering what was going on with that. but yeah, email me or send me a private message w/ anymore info on the subject
Unread 07-01-2008, 17:49
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Please check Rules Update #1.
-dave
Unread 07-01-2008, 18:04
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
-dave
Thanks Dave - I like it when rules get tossed!
No more need to debate or make a ref make a judgement call.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Lettering in opposite stands? corebreach Championship Event 17 28-04-2005 17:32
I MET GENIA! AND HER HEIGHT IS... CourtneyB Chit-Chat 25 22-03-2005 20:35
'Fix It Window' and Programming.... JMac Programming 19 25-01-2005 18:57
Fix-it Window and Mechanisms Don Wright Rules/Strategy 4 24-01-2005 12:01
Suggestion and question... Petey CD Forum Support 7 04-05-2003 16:21
