#7
Re: Eval() in C?
The only limitation is that your functions must take the same datatype. If you need them to take different data types you will need to make them all take a single void pointer to a block of memory then the function will need to reconstruct the data itself. This is probably too complicated and you probably won't need it. just throwing it out there if the need comes up
| Summer camp program eval. | Andrew Schuetze | General Forum | 3 | 12-06-2006 22:16 |
