Go to Post I'm Getting Old. - MrForbes [more]
Unread 07-01-2008, 16:38
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
block thrown ball
you come around corner. other team is in the act of hurdling. do you race in front of him and risk your arm,forklift or whatever your using to block the throw? just another defence maybe.
Unread 07-01-2008, 16:40
GaryVoshol's Avatar
Cogito ergo arbitro
Re: block thrown ball
Without going over 6 feet?
(since 2004)
Unread 07-01-2008, 16:45
Mr.Rush Mr.Rush is offline
AKA: Braden Rush
FRC #0401
Mr.Rush is on a distinguished road
You'd have to stay under 6 feet as they said, avoid impeding traffic, and there is the question why risk losing a scoring ability by tossing you manipulator in front of a 10lb flying object.
Unread 07-01-2008, 16:48
FRC #0910
you would have to be on other side of their home rack
Unread 08-01-2008, 11:50
GaryVoshol's Avatar
Cogito ergo arbitro
And as of Update #1, it could be either side of the overpass.
(since 2004)
Unread 08-01-2008, 11:59
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
That's no longer an issue.
Unread 08-01-2008, 13:02
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
After yesterday's team update, looks like its now legal to do that. I can see teams doing it to- It reminds me of 2 years back in 'Aim High,' where robots would get in the way of other bots trying to score in the higher goal. Seems to me like the same stradegy.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 08-01-2008, 14:11
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We've done the numbers, and it appears very difficult to "throw" the ball over the hurdle, nevermind controlling it on the other side.
Any throwing system will have to be very close the ground to prevent the bot from tipping. In additional, a simple potential energy to kinetic energy computation tells you that you have to hit one of these balls VERY hard to get them to move. 220 lbs of force applied over a 6 inch distance with a 2" bore 6 inch stroke pneumatic cylinder will get you pretty close, I believe.
I can't wait to see someone try this - it would certainly be exciting and any team that takes the chance on that kind of system would get kudos from me!
Even a spring/winch system will put some pretty awesome loads on your chassis.
Unread 08-01-2008, 14:16
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
I'm thinking a pendulum with a 20 lb sledge on the end...Winch it up and then power it down with gravity assisting. Maybe put a football kickers cleat on the end.
RAZ
Unread 08-01-2008, 14:49
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
This assumes, however, that you can get the volume of air to fill the cylinder quickly enough. A 2" cylinder takes a decent amount of time to fill up, given that all the air has to flow through tubing at 60psi. Just because you can achieve 220 lbs of force from a cylinder doesn't mean that you'll be able to deliver enough energy to lift the ball in the air.
Jeff Waegelin
Unread 08-01-2008, 15:12
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
why not bump them so they have to get out of the way
Unread 08-01-2008, 15:20
One problem...aside from robot damage, if the trackball does make it over, you just gave them 8 points because it hit you.
Doesn't work if they aren't impeding you. The ref probably won't call it if there is a passing lane or any other means of going around.
Unread 08-01-2008, 15:26
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Read <G40> ... they don't always have to get out of the way ... only if they are IMPEDING traffic. They don't have to move if there is a way around them (clear passing lane around them), or if they are HURDLING.
Read <G42> and <G43> also ... they discuss that "aggressive" bumping a HURDLER will be penalized ...
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 08-01-2008, 18:09
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Someone's probably said this but (ahem) "You cannot have your arm higher than 6 ft. in the opponent's homestretch".
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 08-01-2008, 18:15
Go read Update #1, and I mean now! <G36> has been removed.
Who has successfully THROWN ringers on to the rack yet? murray2077 Regional Competitions 108 01-04-2007 23:17
ball corral block, good or bad? Lil' Lavery Rules/Strategy 22 02-04-2004 23:35
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
2X Ball Into the Ball Release MikeDubreuil Rules/Strategy 23 28-03-2004 19:31
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
