Re: 6wd - chain path revisited
IMHO... the third design the best with a slight mod.
Directly connect the center wheel to the motor and run chains for each the front and rear wheels from the center (power) wheel. Even if both chains break... you should still have control of your robot... unless the motor goes south... then you DNF. |
Okay - to summarize the inputs so far:
1. having 1 chain - you risk loosing that whole side of the drive train if you pop a chain or it breaks. 2. Love the chain tensioner design by Team 228 as a static chain tensioner. 3. Most seem to like the live axle for the center wheel (or one of the wheels depending on weight distribution). So, a couple specific questions: 1. how about a self adjusting tensioner (spring loaded)? Has anyone had success with these? 2. If you directly connect one wheel to the gearbox output, then your top speed is regulated by the gearbox - correct? we will be using the Kit ToughBox gearboxes - how much of a limitation is this? seems like being able to change the spockets on the wheels would allow for some fine tuning of the speed and torque of the robot. Using a 3 chain design might work best for this? thx again. Bryan |
The first design would rotate the center wheels opposite the outer wheels.
MKRass, I noticed my mistake right after I posted it, and was somewhat embarrased. You are, correct - the middle wheel would be spinning the opposite direction. I don't function well on no coffee, and I know, poor excuse. - can't believe I slipped like that.
Yeah - I noticed that too - meant to draw it with the chain under the sprocket rather than over the sprocket - then they all rotate in the same direction.
i too would choose the last one. I have designed this one for the past 3 years and just continue to improve pond it. Though im running outa things to improve
knock on wood* |
#7
My team has used the three-chain design for two years now, to great success. Though we have never used the kitbot transmissions.
I can't recall the exact shaft size we used for our axles, but I do remember that, two years ago, by the time we were half way through the qualifying rounds, the bolts we used were toast. We upgraded to some grade 8 bolts of the same size and haven't had a problem since. Though, getting those bent axles out of our wheels was a bit of a challenge I must admit. You can see a picture of the design we used two years ago here. I couldn't find much of a shot of the drive train from last year. Other than the bent axles, the only trouble we ever had was getting those poof-balls stuck in the chains. We actually cut one in half during a match once, that was pretty cool... well, until it finally popped one of the chains off anyways. *Hopefully* we won't have a problem with that this year though... |
#8
One more possibility would be to omit the tensioners at all.
Use a live center axle If you use sprockets with an even tooth count and space them an even multiple of the chain pitch apart in a single drive/driven configuration you would be able to keep it really simple. If the chain stretches enough to need tensioning throw it out. It's really not worth losing the chance to go to Atlana for a couple of bucks worth of streched chain. You also don't need the extra hardware needed for tensioning to complicate things as well. (in the dark, on carpet ... with a ref asking you if you can continue. been there ... unfortunately done that... GTR finals 05) Last edited by B.Johnston : 07-01-2008 at 20:04. |
#9
I would recomend the last setup (your third picture). That is the same as the drivetrain we had last year and we had zero problems.
Our first year we tensioned our chain by moving the wheel axles, and it didn't work well at all. Chain tensioners are not as much of a hassle as they are made out to be, and if they are done right they work very well. Here's a picture of some of our tensioners from last year. What kind of transmissions are you using? |
#11
Here's a YouTube video of 1583's 6wd. http://www.youtube.com/watch?v=px-QCB9UeCsa It uses a single drive chain. We ran a similar design last year with no problems.
#12
Here's a working youtube video link. http://www.youtube.com/watch?v=px-QCB9UeCs
#13
Personally, I love robot drive trains that once they are designed, built, and assembled, you can more or less forget about them. (As opposed to constantly tweaking them between matches.) Nothing is better than going to a competition, getting through inspection Thursday morning, and relaxing in the pits between matches, because nothing broke or needs to be replaced. |
#14
Our team has been using the second arrangement as shown in your original drawing. The only difference might be with the orientation of the chain tensioner. We tried out a live axle last year and it did what it was supposed to but the extra work didn't seem to buy us much. This year we are going to try a 1/2 inch diameter bolt as our axle and mount the wheels on bearings. In the end it is really just figuring out what works best for your team.
| White Paper Discuss: Dr Joe's Chain Path Visualizer | Joe Johnson | Extra Discussion | 10 | 24-11-2008 18:31 |
| 6WD chain path | Bill_Hancoc | Technical Discussion | 18 | 13-12-2006 17:08 |
| Inventor file path help | Rickertsen2 | Inventor | 3 | 08-04-2006 12:54 |
| FIRST On A Disturbing Path | DCaldwell05BCP | General Forum | 69 | 15-04-2003 14:58 |
| Chain and chain breaker source? | kmcclary | Off-Season Events | 4 | 22-10-2001 22:51 |
