Go to Post The more interesting arguments were around a related subject: whether it was pronounced "Wago tool" or "screwdriver". - Billfred [more]
Unread 07-01-2008, 18:47
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Re: 6wd - chain path revisited
Yeah - I noticed that too - meant to draw it with the chain under the sprocket rather than over the sprocket - then they all rotate in the same direction.
Unread 07-01-2008, 19:00
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
i too would choose the last one. I have designed this one for the past 3 years and just continue to improve pond it. Though im running outa things to improve knock on wood*
Unread 07-01-2008, 19:43
JagWire's Avatar
JagWire JagWire is offline
Team 1742 College Mentor
AKA: Tim Long
FRC #1742 (Shockwave)
JagWire has a spectacular aura aboutJagWire has a spectacular aura about
Send a message via AIM to JagWire
My team has used the three-chain design for two years now, to great success. Though we have never used the kitbot transmissions.
I can't recall the exact shaft size we used for our axles, but I do remember that, two years ago, by the time we were half way through the qualifying rounds, the bolts we used were toast. We upgraded to some grade 8 bolts of the same size and haven't had a problem since. Though, getting those bent axles out of our wheels was a bit of a challenge I must admit. You can see a picture of the design we used two years ago here. I couldn't find much of a shot of the drive train from last year.
Other than the bent axles, the only trouble we ever had was getting those poof-balls stuck in the chains. We actually cut one in half during a match once, that was pretty cool... well, until it finally popped one of the chains off anyways. *Hopefully* we won't have a problem with that this year though...
Team 1742: Shockwave
2006 Robot "Sprocket"
2007 Robot "Rampzilla"
2008 Robot "Trigonosaurus"
Aut viam inveniam aut faciam.
I'll either find a way or make one.
www.team1742.com
Unread 07-01-2008, 20:00
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
One more possibility would be to omit the tensioners at all.
Use a live center axle
If you use sprockets with an even tooth count and space them an even multiple of the chain pitch apart in a single drive/driven configuration you would be able to keep it really simple.
If the chain stretches enough to need tensioning throw it out.
It's really not worth losing the chance to go to Atlana for a couple of bucks worth of streched chain.
You also don't need the extra hardware needed for tensioning to complicate things as well.
(in the dark, on carpet ... with a ref asking you if you can continue. been there ... unfortunately done that... GTR finals 05)
Name:	chain looping.PNG
Unread 07-01-2008, 21:10
JHSmentor's Avatar
FRC #3210 (Falcons)
Unfortunately, we built a 2wd robot for an earlier competition and the chains stretched enough during the game that they tended to jump off. Using #25 chain just seems to require it if you have any distance to cover with it. Anyone else concure or disagree? all inputs are welcome. thx.
Unread 07-01-2008, 22:42
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I would recomend the last setup (your third picture). That is the same as the drivetrain we had last year and we had zero problems.
Our first year we tensioned our chain by moving the wheel axles, and it didn't work well at all. Chain tensioners are not as much of a hassle as they are made out to be, and if they are done right they work very well. Here's a picture of some of our tensioners from last year.
What kind of transmissions are you using?
Unread 07-01-2008, 22:47
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Here's a YouTube video of 1583's 6wd. http://www.youtube.com/watch?v=px-QCB9UeCsa It uses a single drive chain. We ran a similar design last year with no problems.
Unread 07-01-2008, 23:11
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Here's a working youtube video link. http://www.youtube.com/watch?v=px-QCB9UeCs
Unread 07-01-2008, 23:34
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If your team attends multiple competitions, it's a lot cheaper and more robust to just use a chain tensioner than to constantly keep replacing roller chain because it stretched.
Personally, I love robot drive trains that once they are designed, built, and assembled, you can more or less forget about them. (As opposed to constantly tweaking them between matches.) Nothing is better than going to a competition, getting through inspection Thursday morning, and relaxing in the pits between matches, because nothing broke or needs to be replaced.
Art Dutra IV
世上无难事,只怕有心人.
White Paper Discuss: Dr Joe's Chain Path Visualizer Joe Johnson Extra Discussion 10 24-11-2008 18:31
6WD chain path Bill_Hancoc Technical Discussion 18 13-12-2006 17:08
Inventor file path help Rickertsen2 Inventor 3 08-04-2006 12:54
FIRST On A Disturbing Path DCaldwell05BCP General Forum 69 15-04-2003 14:58
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
