Go to Post As it stands your design defies physics (and breaks 1 of Karthik's 2 Golden Rules). - JesseK [more]
Unread 07-01-2008, 18:46
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Suggestion to Fix Rules of Height, and Opposite TrackBall
Originally Posted by Chris_Elston View Post
1. Cross the Finish Line, and reach backwards to get your ball.
2. Use another ball.
3. We are checking this one..field not done yet...but over pass is 6.5, ball droops down into the 6.0 feet range, 7" droop maybe??? you might be able to stick up right at the 6 feet mark, and still barely scrap the bottom of the trackball from bottom....again...still checking into that one...
that's a couple.
1> Incurs a 10 point penalty for breaking the plane of the finish line, but is possible to do.
2> Only if you throw the 'other ball'. But is legal.
3> You'll have about 1" of contact space ... not much there to hit.
Also you can:
4> Strike the portion of the ball that overhangs the finish line ... you'll have ~ 2-3" contact space there
5> Reach over from the other lane ... you'll need to make sure you don't violate the 80" cylinder rule or break the plane of the finish line.
EDIT --- ***Dang it Dave .... Why didn't you post yours before I started typing ***
___________________
- Tennyson, Ulysses
Unread 07-01-2008, 18:55
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
This issue was resolved in Update #1 - I'm closing this one in order to clean up the number of posts no longer needed.
Mike Aubry
Chief Delphi Engineering Lead
Lettering in opposite stands? corebreach Championship Event 17 28-04-2005 17:32
I MET GENIA! AND HER HEIGHT IS... CourtneyB Chit-Chat 25 22-03-2005 20:35
'Fix It Window' and Programming.... JMac Programming 19 25-01-2005 18:57
Fix-it Window and Mechanisms Don Wright Rules/Strategy 4 24-01-2005 12:01
Suggestion and question... Petey CD Forum Support 7 04-05-2003 16:21
