Go to Post At FIRST, our only colors are red or blue. And we are only those for two minutes! - tenfour [more]
  #121   Spotlight this post!
Unread 06-01-2008, 18:03
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by CPress View Post
Where can I get that?
Please define "that".
If you mean MPLAB 8.0 and C18 v3.1, please read the very first page.
If you are referring to MPLAB 7.4 and C18 v2.7, look in the KOP for the CBOT CD.
  #122   Spotlight this post!
Unread 06-01-2008, 23:20
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Originally Posted by Code Monkey View Post
For those who have not already installed the MCC upgrade, make sure you put it in the same directory with the upgraded MPLAB 8.0. Otherwise the linker can't find the libraries. I know by the trying it the wrong way.
For people having issues with new MPLAB IDE and new C18 playing nice together:
When installing/updating your C18 compiler, (I went with 3.15 and am going to add the #endif that was mentioned earlier) there is a page of options after choosing which components to install that has the following:
[ ] Update MPLAB IDE to use this MPLAB C18
[ ] Update MPLAB IDE to use this MPLINK Linker, MPLIB Librarian, and MPASM Assembler
Check them!
What place are we at? ... TODAI!
  #123   Spotlight this post!
Unread 07-01-2008, 00:45
SuspectZero's Avatar
SuspectZero SuspectZero is offline
2254 Team President
FRC #2254 (Twisted Transistors)
SuspectZero is an unknown quantity at this point
Check them!
Edit: apparently that doesn't actually do the trick. I still get this:
MPLINK 4.15, Linker
Copyright (c) 2007 Microchip Technology Inc.
Error - could not find file 'clib.lib'.
Errors : 1
Link step failed.
for the clib.lib error go to Project> Build Options> Project> Directories Tab. in the Show Directories menu, select library search path. delete the old one and create a new one where the clib.lib is located (a simple search on your computer should be able to find it). i dont know if you should but you can also do the same with the Linker-Script Search path, in which you should delete the old directory location and create a new one going to the lkr folder in your mcc18 folder. that should fix the problem
can someone point me in the direction of a tutorial in which i can use this code to program our new 2008 bot? also is there a way of reading the printf statements in an executed program without having to upload onto our robot?
Team 2254: Twisted Transistors
2007 FRC: Placed 18th in Regionals
2008 FRC: TBD
  #124   Spotlight this post!
Unread 07-01-2008, 01:01
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
If you take Kevin's simple code and just read it, there's a fair chance you'll be able to do the simple stuff (i.e. left joystick forward = left motor forward) by yourself pretty easily. Reading the aliases in ifi_frc and seeing that the joysticks are referred do as p1_y for the y-axis, for example, and that pwm channels are simply pwm01 through 16 also helps. Where you want to start writing code is the Teleop() function in teleop.c, as that is the function that is called upon receiving data in the teleoperated mode.
As far as prtinf goes, if you place your robot on blocks (so that the wheels are spinning freely and not touching anything) and you keep the programming cable connected to the computer, you will see the results of all printf's in the terminal window that pops up after you're done downloading code usinng IFI Loader.
Hope this helps.
  #125   Spotlight this post!
Unread 07-01-2008, 11:42
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Originally Posted by Kevin Watson View Post
The officially supplied version is 2.4, but a free upgrade to 3.10 (don't use 3.15) is available on Microchip's website. I haven't tested it yet, but the freebie student version will probably work just fine. For those who want to stick with 2.4, I just built a version that will work with the older compiler. After I do a bit of testing, I'll post a link to it.
-Kevin
I can confirm that as long as you make the change Mark McLeod described in this post. The C18 3.15 Student Edition compiler works just fine.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
  #126   Spotlight this post!
Unread 07-01-2008, 16:03
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Hey, i really like the look! I'm having this problem when i try to compile:
MPLINK 4.1, Linker
Copyright (c) 2006 Microchip Technology Inc.
Error - could not find file 'C:\2008 FRC\frc_library_24\ifi_frc_8722_24.lib'.
Errors    : 1
how to fix?
EDIT: Fixed it (for anyone else, add the library file again (project menu) wherever you installed it)
now i'm getting:
MPLINK 4.1, Linker
Error - Coff file format for 'ifi_frc_library.o' is out of date.
Error - Could not build member 'ifi_frc_library.o' in library file 'Z:\My Documents\robotics\ifi_frc_24\ifi_frc_8722_24.lib'.
Errors    : 2
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
  #127   Spotlight this post!
Unread 07-01-2008, 16:13
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
MPLINK 4.1, Linker
Errors    : 1
how to fix?
The project file is messed up a little. I attached a zipped copy of the .mcp file for the gyro and non-gyro versions. Replace the existing one with that one, and it should work.
THIS IS .MCP FILES ONLY! NO CODE!
EDIT: Are you using c18 v3+ to compile the v2.4 code?
Eric Haskins KC9JVH
  #128   Spotlight this post!
Unread 07-01-2008, 16:18
paulcd2000's Avatar
AKA: Paul Dagnelie
i believe i am. you download that from the microchip website? i have...
V 3.1
  #129   Spotlight this post!
Unread 07-01-2008, 16:19
AKA: Eric Haskins
V 3.1
If you are using v3.1 you need to download the verison of the code for c18 v3+. It is listed on the first post of this thread.
Eric Haskins KC9JVH
  #130   Spotlight this post!
Unread 07-01-2008, 16:23
paulcd2000's Avatar
AKA: Paul Dagnelie
i did download that one.
EDIT: oops... i didn't! Ok, well which of the various links is it? is it "the snapshot of the latest build"
  #131   Spotlight this post!
Unread 07-01-2008, 16:27
AKA: Eric Haskins
The library file reference in the error you posted is the v2.4 version.(you can tell by the "_24" ending of the library file and the project directory) Unless kevin included the wrong library you accidentally grabed the wrong file.
The first three links are 3+. The other two are v2.4.
Eric Haskins KC9JVH
  #132   Spotlight this post!
Unread 07-01-2008, 16:44
Kevin,
In the gyro.h file there are definitions for several different gyros. However, the new KoP gyro is not one of them. Do you think you will be able to add a set of constants for it next time you rebuild?
Thanks.
  #133   Spotlight this post!
Unread 07-01-2008, 20:10
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
Sorry,
Not to drag everyone back to v2.4... but
Ive tried both a last years install and this years mplab v7.2 with 2.4 and it won't even open the 2.4 verion of the beta's project file.
There has been previous mention of mplab7.4 with 2.7.
This is not the version in our Canadian Kits.
Could we please clarify?
  #134   Spotlight this post!
Unread 07-01-2008, 20:44
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by sumadin View Post
Kevin,
Thanks.
I believe the KOP gyro has the same sensitivity (the important parameter to match) as the ADXRS150, which is already supported. I'll look into it and get back to you...
-Kevin
Kevin Watson
http://kevin.org
  #135   Spotlight this post!
Unread 07-01-2008, 20:51
FRC #2429
Originally Posted by 1680Bruce View Post
Sorry,
All versions of the code have project files created with version 8.00 of MPLAB. You can either upgrade to 8.0 for free or just use the project wizard to create a new project. Sorry about the hassle, but it seems like every new version of MPLAP uses a different format for the project files.
-Kevin
Kevin Watson
http://kevin.org
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
