Go to Post That little voice in your head is not Ari telling you to keep going. It is your guardian angel telling you to stop! - Al Skierkiewicz [more]
Unread 07-01-2008, 21:46
pwilczynski's Avatar
pwilczynski pwilczynski is offline
FRC #0236 (Techno Ticks)
Rookie Year: 1993
pwilczynski is on a distinguished road
Mecanum Motors
Our team has been so excited to try out a mecanum drive this year. However, a reality check has set in that we will likely have extreme difficulty with this due to the fact that there are no four identical (or close to identical) motors. Does anyone know a way to get a mecanum drive working with the given motors mechanically, or will it just require some fairly intense programming ?
2006 UTC Chairman's Award
Unread 07-01-2008, 21:57
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
Re: Mecanum Motors
You can purchase 2 additional 2.5" CIM motors to use on your robot.
Unread 07-01-2008, 21:59
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
Re: Mecanum Motors
<R59> says you can have up to four 2.5" CIMs, but of course you'll have to purchase the extra two.
Unread 07-01-2008, 22:05
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: Mecanum Motors
first you have to ask yourself what you want to be able to do,
do you want a drive system that is truly holonomic
(ie you need 4 motors)
or is merely strafing enough
(can be done with 2 motors and 2 fwd/rev transmissions)
or do you want a strafing and diagonal drive system.
(can be done with 2 motors, 2 fwd/rev transmissions, and 4 on/off transmission)
Unread 08-01-2008, 08:44
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Mecanum Motors
use encoders or the KOP gyro
Unread 08-01-2008, 10:07
Mr.Rush Mr.Rush is offline
AKA: Braden Rush
FRC #0401
Mr.Rush is on a distinguished road
Re: Mecanum Motors
Team 401 used mecanum last year to some success. Using encoders on them isn't very reliable as mecanum its self slips a lot and your feedback will be off.
Using 4 CIM motors with banebot gear boxes is the way to go, just keep the robot balanced.
Unread 11-01-2008, 12:29
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
Re: Mecanum Motors
We had a mecanum drive last year with great success. Balance is the key. Our drive only drifted a little and we had no encoders. We are using the same drive system this year with encoders. The mecanum wheels we purchased last year from AndyMark required a lot of work to assemble and modify. We did not find AndyMark wheels to be precisie enough, holes didn't line up, rollers were not perpendicular to their mounting plate sections. Where else, besides AndyMark, can we get 8" mecanum wheels?
Unread 11-01-2008, 13:29
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: Mecanum Motors
I've heard the 6in ones are much better because it's a whole plate, no tabs like the 8in ones.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 11-01-2008, 14:24
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Re: Mecanum Motors
You can't, the only place that sells mecanums for FIRST robots is andymark. There are other companies that use mecanums but for the most part they simply use them in their own vehicles and don't sell the wheel separate. In addition these compainies make things like forlifts and you aren't going to find a small enough wheel.
For the actuall control I would strongly suggest using a gyro instead of encoders, the code is easier and it isn't suseptible to slipping. I have done a holonomic for the past 3 years and last year ours was a rock, it didn't drift, it went in a perfectly straight line and overall just ran extremely well and we didn't use encoders, just a gyro.
Unread 11-01-2008, 14:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Mecanum Motors
I'm curious - if you did not use encoders, how did you measure distance driven?
Unread 11-01-2008, 16:24
Fidgetting
Re: Mecanum Motors
You could use a linear accelerometer and integrate it over time to get distance. However if you want distance you probably want to use an encoder, but for the basic control of a mecaum bot you don't need distance traveled. What usually makes a mecanum uncontrollable is drifts in rotation because this can cause the bot to swerve to one side or drift in the wrong direction, for this you can integrate a gyro. While this may sound dificult it is easier than programing in interupts (or at least that is what I have always found).
Unread 11-01-2008, 17:20
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Mecanum Motors
That is technically wrong and right at the same time.
Yes, it looks like Andymark is the only place to buy a Mecanum wheel off the shelf... but... as with other things you COULD actually buy something that uses a Mecanum wheel and strip it off of it to use.
Nothing in the rules says you have to use the whole item that you buy, but it does say you have to account for it in your budget.
Hypothetical Situation: You buy a Remote controlled car with Mecanum wheels already on it and strip them off for use on your robot.
You must include the whole price of that Remote controlled car (which may be outrageous yes, this is true but this is just an example) in your final Bill Of Materials.
The Wheels would go in your Bill of Materials for your robot.
The whole cost of the Remote controlled car would need to be listed in the price portion of your data to prove you came in under budget.
All I'm saying is that you don't have to limit yourself to something just because it's "not available anywhere else" as a singular entity.
If you find a shopping cart has cool wheels you want to use, but can't find those exact wheels for sale anywhere else, just buy the whole shopping cart, strip the wheels off, put the wheels in your Bill Of Materials, and write down how much you paid for the shopping cart (even if you did get it for "free" from a store... (as a legitimate donation of course..)
Unread 14-01-2008, 15:17
D_Price's Avatar
D_Price D_Price is online now
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
Re: Mecanum Motors
I have a question...what is needed to really program the mecanum wheels.. Is there a special code to use in programming or is it in the basic language?
private message me.
Unread 14-01-2008, 18:12
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: Mecanum Motors
last year we set it up so you could change the power each motor gave out using a knob for each motor. That way you can fine tune the power of the motors till they are equal
FEAR THE HAWK!!!
Motors, Motors, and More Motors 1033missions Motors 1 09-02-2006 18:46
Motors.. and more motors.. How many on your 2004 bot? OneAngryDaisy Motors 33 23-02-2004 00:46
Matching Drill Motors and Fischer-Price Motors archiver 2001 5 24-06-2002 00:51
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
F.P. Motors & gearbox for $12.50 Window Motors $19.50 archiver 2001 1 23-06-2002 23:05
