Go to Post Thanks, that clears things up a lot, and should probably have been obvious. - Branden Ghena [more]
Unread 07-01-2008, 21:44
Chris1228 Chris1228 is offline
FRC #1228
Chris1228 will become famous soon enough
PROGRAMMING PROBLEM HELP!
Hey as the title states i have a problem with mp lab and would like some assistance. I am using the FRC Code_2007_8722 and when i go to build the program i get this error message "C:\Documents and Settings\Christopher\Desktop\frc-code-2007-8722\FrcCode_2007_8722\user_SerialDrv.c:52:Error: syntax error"
and my code where te error supossively is :
"typedef DeviceStatus *DeviceStatusPtr;
//static PANEL_INPUT_RECORD dataIn; /* data input buffer (from Breaker Panel) */
static unsigned char IntState;
static panel_bitid bpFlags; [/color]
static DeviceStatus dcb[TOTAL_SERIAL_PORTS]; /* device control block */
unsigned char aBreakerWasTripped;
static char rom2ramBufr[12];
" with the error arrow at the line static panel.
What do i do? help please
Unread 07-01-2008, 21:52
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: PROGRAMMING PROBLEM HELP!
I'm not sure what you are trying to do here, but I have never seen anything put after a semicolon. I'm not sure if you were trying to comment out COLOR, or if it serves a purpose. May be something to look at, but I'm not guaranteeing thats the problem, so dont go to crazy with it. Hope it helps.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 07-01-2008, 22:01
FRC #1228
"sorry that color part was a typo" see anything else wrong? i really need 2 fix this problem
Unread 07-01-2008, 22:16
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
First, considering the length of your path to that file, you're running perilously close to the 64 character limit for the files path for the compiler. I'd consider moving the code from your desktop to a root directory.
Second, have you previously defined DeviceStatus somewhere?
Unread 07-01-2008, 22:22
FRC #1228
ok so where should i move the code to?
Unread 07-01-2008, 22:36
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
I keep mine in a folder directly on the C drive, and it seems to work.
Also, what are you doing with that last line? is that an arguement or an atempt at an array/vector, becuas eif so that may be it. I don't know about that in this enviroment, so it may be entirely legal.
Course, the file length may be your problem anyway, so try that before anything else.
Unread 07-01-2008, 22:37
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
The path length limit would probably create a whole mess of error messages.
The C programming language is quite free form. You can put anything you want after a semicolon, including another command or comments. It is quite common to see these type of comments.
I cannot see any problems with your code. So that means add each line one at a time and see which one produces the error. You can facilitate that by commenting them out.
/Jason
Unread 07-01-2008, 22:42
FRC #1228
Well i tried moving the code into a folder directly in the c drive and recieved the same error message. should i try putting the lines of code in one at a time to see which one produces the error?
Unread 07-01-2008, 22:43
FRC #1228
And none of my programs will build is that a problem with mp lab?
Unread 08-01-2008, 10:11
Since you've modified the default code it is probably something earlier that caused the error you're seeing.
Try compiling an original version of the default code and get that working first.
Unread 08-01-2008, 11:12
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
First off, a quick google search revealed your SVN repository, so you might want to protect that. That being said, i took a look over your source, and couldn't find anything that looked wrong.
One problem i've had in the past taht's really hard to find is line endings - Unix line endings are different from the DOS ones, and if you accidentally intermix them in a file, some compilers will start throwing fits. In the definition of PANEL_INPUT_RECORD in your header file, you have a variable of type panel_bitid, so it's a fairly safe bet that it's not the struct that's causing the problem.
Unread 08-01-2008, 19:37
FRC #1228
so what should i do? i dont have anyother variation of a default code
Unread 09-01-2008, 11:58
Use the original released by IFI: http://www.ifirobotics.com/docs/frc-code-2007-8722.zip
The code snippet you posted earlier shows a line commented out, so it's been modified from the original.
Make sure the original compiles "as is" for you, then start adding your modifications, compiling and checking each modification as it's added. You'll catch where you've gone wrong.
Unread 09-01-2008, 12:19
ubergeek5075's Avatar
ubergeek5075 ubergeek5075 is offline
FRC #0910 (Foley Freeze)
ubergeek5075 is an unknown quantity at this point
Whenever we have a syntax error in our code, and our code on the line and after the line is grammatically correct, our next step is to make sure we aren't defining something previously defined.
Then we look at the code above it for syntax errors. For instance, if you have a line of code before that like this:
int new_variable
and forget the semicolon, then it will cause the error on the next line following. Same goes for braces and brackets, etc.
The only other thing i can think of is that the typedef is inside a function, which causes problems.
Easy C programming Problem fredliu168 FIRST Tech Challenge 6 19-11-2006 22:44
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
C programming problem... wasabi824 Programming 5 08-02-2004 01:04
multi-bank programming problem GregC Programming 3 14-02-2003 16:13
programming problem gthakore Programming 16 20-04-2002 12:21
