Go to Post Mike Wade was the Fall offseason guy. - Michael Leicht [more]
Unread 07-01-2008, 21:46
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
Re: Silly and ridiculous robot designs.
Originally Posted by Don Rotolo View Post
For this year's game, a "Motorcycle bot". 2 wheels.
I had thought of something similar, but a little more wacky. Instead of motorcycle, more like a tricycle. The electronics are housed ina thin tall and long box. sticking out the front is a wheel on a servo that can rotate. on the back are two powered wheels sticking out at an angle (about 15 degrees) on the end of pistons. When the tricycle speeds around a turn, the inside piston retracts so the tricycle 'banks' through the turn. Someone later pointed out to me that i wont even need the right piston because we'll only be turning left :-)
Unread 07-01-2008, 21:56
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
My favorite design was basically we somehow load the ball into a bowl like structure on a pole going out the back of our bot, the pole would be able to rotate probably 90 degrees so in the end it could be vertical. so we pick up the ball and line up a few feet away from the overpass. four pneumatic actuator things extend from the corners of the bot lifting it a couple feet in the air. the front actuators close violently throwing the ball forward over the overpass.
My idea... if only it didn't violently shake the base of the robot and make the base fall roughly two feet
Unread 07-01-2008, 22:09
smartkid's Avatar
smartkid smartkid is offline
Boom!
AKA: Cody Smith
FRC #1902 (Exploding Bacon)
smartkid has a spectacular aura aboutsmartkid has a spectacular aura about
Helicopter bot... If you could somehow pull that off and if it could hold the ball, that would be so freaking effective.
Hummmmmm... lol
Unread 07-01-2008, 22:11
team1203 4life's Avatar
team1203 4life team1203 4life is offline
President
FRC #1203 (Pandemonium)
team1203 4life is a jewel in the roughteam1203 4life is a jewel in the roughteam1203 4life is a jewel in the rough
Send a message via AIM to team1203 4life
Originally Posted by Rysonue View Post
I'm sure every team has come up with some pretty ridiculous designs. Those overtly comedic designs put forward soley to make a funny. What are the ridiculous designs your team has come up with?
Our most ridiculous design has, so far, been the concept of "Injecting the hamsters." I'm fairly certain no one has ever... EVER uttered that sentence(except us.) We also joked about a helicopter design, except we realized it would still need bumpers on it. We solved that problem by making the blades the bumpers, so I guess magic would make it fly.
So what are your ridiculously wacky designs?
well last year we had the idea to release a monke on to the rack so no one could score
Unread 07-01-2008, 22:18
bkwrm92 bkwrm92 is offline
AKA: Benjamin George
FRC #0195 (Cyberknights)
Team Role: Mascot
bkwrm92 is an unknown quantity at this point
Send a message via AIM to bkwrm92
We thought about building a PORTAL gun for this years game. We did mock ups of the bot with it and everything, we would have the game controller be a USB mouse and attach a 5 in game screen to the control panel. Yeah... we decided that the laws of time and space didn't exist for a day.
This was a triumph!
Unread 07-01-2008, 22:20
Nate Laverdure's Avatar
FRC #2363
A monkey? Or a monk? I can't shake the image of a cloaked and balding seminarian climbing through the layers of the rack, fending off attacks by robots carrying inflatable rings.
Unread 07-01-2008, 22:21
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Well... our crazy idea is in this thread.
But the "release the hamsters" reminded me of my favorite part of the manual (it's been in it for a few years)- go to Section 8, pg. 30. In the left-hand column, in the bottom bubble, it shows that gerbils may not be used as an energy source.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 07-01-2008, 22:39
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
Since your robot may not be taller than 6 feet in the Opponent's Home Stretch, I considered a jumping robot. Or trained squirrels running the robot.
Edit: Yes, ydnar90, very true. I did come up with this before they changed the rules, but thank you for pointing this out. The robot would have jumped on springs...
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 07-01-2008, 22:44
ydnar90
Posts: n/a
Blue Mist you need to check FIRST's updates. They got rid of the 6ft limit. You can go as high as you want at any point on the field. The only limit is the overpass and the height of where you are playing
Unread 07-01-2008, 22:46
reflion reflion is offline
Design Team 2204
FRC #2204 (Rambots)
reflion is an unknown quantity at this point
Haha, this is my first year on the team, so my friends and I came up with some incredibly implausible stuff:
-A flechette bot: One robot unfolds into twenty, which zoom around the course getting two points for every time they cross the finish line.
-A version of metal gear rex.
-A giant snail, where the balls would be pushed through a helical shell then flicked over the hurdle.
-Me in a box.
-A fire paradox which shoots out fire then puts it out with a water gun simultaneously. For absolutely no use besides the awesome factor.
-A robot with a harpoon gun to pull balls off the hurdle.
And of course, every robot has onboard speakers playing Metallica. As per design instructions.
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
"The Iron Curtain" - A robot that pulls an entire sheet over your opponent's viewing area. The most un-GP robot you could ever build...it's not even really funny. hahaha
We are building the Mach 5 this year.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
I don't want to be mean to freshmen but....
Apparently, in the designs of freshmen, the laws of physics do not apply and neither do the relative forces of motors. Also, we are going to use pneumatics to repeatedly launch the balls over overpasses from ground level.
-vivek
"we don't build robots, we build people"
Unread 07-01-2008, 22:48
BeyondRamo's Avatar
BeyondRamo BeyondRamo is offline
AKA: Omar
FRC #0334 (Tech Engineers)
Team Role: Electrical
BeyondRamo is an unknown quantity at this point
The craziest is a penguin styled robot. Lol. I have no idea that would work.
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Originally Posted by XxMORTteam11xX View Post
A giant caaage
lol jk
hahahahahahaa
(kinda an inside joke)
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Making a wooden trebuchet robot would be pretty cool...
After looking at the pink team's 'teaser', it may actually be a viable strategy.
Its getting to be RIDICULOUS! Marygrace General Forum 42 15-01-2008 17:35
Ridiculous Download Time? TommyT Programming 4 07-02-2004 23:43
I am silly. FotoPlasma Chit-Chat 15 07-01-2003 09:55
Robot designs Huskie65 OCCRA 1 09-10-2002 13:23
Writing and Images on Inventor Designs Jan Olligs Inventor 0 23-02-2002 11:44
