Go to Post ...sitting immediately behind Chief Delphi is a bad idea. I like the team and all, but they've given me a massive headache...They've got too much spirit. - IMDWalrus [more]
Unread 07-01-2008, 19:00
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Re: 6wd - chain path revisited
i too would choose the last one. I have designed this one for the past 3 years and just continue to improve pond it. Though im running outa things to improve knock on wood*
Unread 07-01-2008, 19:20
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Originally Posted by JHSmentor View Post
I am a mentor for a rookie team - hence, I am a rookie as well.
We have been researching 6wd systems and am curious what the pro's and con's are for the chain paths that could be used. I've included some very rough drawings (please don't pick on me too much over these!) to illustrate what we have been discussing.
I have my own ideas of some pro's and con's for these designs but would like some unbiased feedback so I will keep those to myself for now.
things to consider are drag created by the tensioners (if any), chain stretch even with the tensioners, dropping a chain, sprocket changes, wheel changes, stuff like that.
we will most likely be using as much of the kit parts as possible and filling in any gaps with similar or identical equipment - unless there are other cheap alternatives presented here.
thanks for the help!!
PS. the blue circles are the tensioners (still trying to figure these out), red are the sprockets, and the light blue are wheels - probably a mix of Omni's and kit wheels.
i updated the image to correctly draw the chainpath for the first image.
Unread 07-01-2008, 19:31
BenjyPoore's Avatar
BenjyPoore BenjyPoore is offline
Squenjy the Squirrel!
FRC #1519 (Mechanical Mayhem)
BenjyPoore is on a distinguished road
Send a message via AIM to BenjyPoore
I like the second method best. This way if you break a chain or two you are in no way out of commission. I would use #35 chain for the motor-center wheel link, then #25 for the other 2 chains. This saves weight while still having some dependable #35 chain on there.
Unread 07-01-2008, 19:43
JagWire's Avatar
JagWire JagWire is offline
Team 1742 College Mentor
AKA: Tim Long
FRC #1742 (Shockwave)
JagWire has a spectacular aura aboutJagWire has a spectacular aura about
Send a message via AIM to JagWire
My team has used the three-chain design for two years now, to great success. Though we have never used the kitbot transmissions.
I can't recall the exact shaft size we used for our axles, but I do remember that, two years ago, by the time we were half way through the qualifying rounds, the bolts we used were toast. We upgraded to some grade 8 bolts of the same size and haven't had a problem since. Though, getting those bent axles out of our wheels was a bit of a challenge I must admit. You can see a picture of the design we used two years ago here. I couldn't find much of a shot of the drive train from last year.
Other than the bent axles, the only trouble we ever had was getting those poof-balls stuck in the chains. We actually cut one in half during a match once, that was pretty cool... well, until it finally popped one of the chains off anyways. *Hopefully* we won't have a problem with that this year though...
Team 1742: Shockwave
2006 Robot "Sprocket"
2007 Robot "Rampzilla"
2008 Robot "Trigonosaurus"
Aut viam inveniam aut faciam.
I'll either find a way or make one.
www.team1742.com
Unread 07-01-2008, 20:00
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
One more possibility would be to omit the tensioners at all.
Use a live center axle
If you use sprockets with an even tooth count and space them an even multiple of the chain pitch apart in a single drive/driven configuration you would be able to keep it really simple.
If the chain stretches enough to need tensioning throw it out.
It's really not worth losing the chance to go to Atlana for a couple of bucks worth of streched chain.
You also don't need the extra hardware needed for tensioning to complicate things as well.
(in the dark, on carpet ... with a ref asking you if you can continue. been there ... unfortunately done that... GTR finals 05)
Name:	chain looping.PNG
Unread 07-01-2008, 21:10
JHSmentor's Avatar
FRC #3210 (Falcons)
Unfortunately, we built a 2wd robot for an earlier competition and the chains stretched enough during the game that they tended to jump off. Using #25 chain just seems to require it if you have any distance to cover with it. Anyone else concure or disagree? all inputs are welcome. thx.
Unread 07-01-2008, 22:42
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I would recomend the last setup (your third picture). That is the same as the drivetrain we had last year and we had zero problems.
Our first year we tensioned our chain by moving the wheel axles, and it didn't work well at all. Chain tensioners are not as much of a hassle as they are made out to be, and if they are done right they work very well. Here's a picture of some of our tensioners from last year.
What kind of transmissions are you using?
Unread 07-01-2008, 22:47
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Here's a YouTube video of 1583's 6wd. http://www.youtube.com/watch?v=px-QCB9UeCsa It uses a single drive chain. We ran a similar design last year with no problems.
Unread 07-01-2008, 23:11
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Here's a working youtube video link. http://www.youtube.com/watch?v=px-QCB9UeCs
Unread 07-01-2008, 23:34
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If your team attends multiple competitions, it's a lot cheaper and more robust to just use a chain tensioner than to constantly keep replacing roller chain because it stretched.
Personally, I love robot drive trains that once they are designed, built, and assembled, you can more or less forget about them. (As opposed to constantly tweaking them between matches.) Nothing is better than going to a competition, getting through inspection Thursday morning, and relaxing in the pits between matches, because nothing broke or needs to be replaced.
Art Dutra IV
世上无难事,只怕有心人.
Unread 08-01-2008, 07:04
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Originally Posted by Teched3 View Post
We drive each wheel of a six wheel drive robot with an individual chain for each wheel. Hence, if a chain (or two) breaks or comes off, you still can drive and control your robot.
That is what we did last year as well. One thown chain does not take out the entire drive on one side of your bot.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 08-01-2008, 10:24
shock190 shock190 is offline
AKA: Andrew
FRC #0190 (Gompei and the H.E.R.D.)
shock190 is an unknown quantity at this point
Team 190 used the bottom design with no failures through two regionals, championships, and a good half dozen offseasons and a few dozen demos with no failures or chains dropped. For tensioners we simply had rollers of varying sizes we could swap on and off instead of an adjusting mechanism.
Team 190 - Building the ridiculous since 1992
2008 BAE Granite State Regional Leadership in Controls
2008 Silicon Valley Regional Creativity Award
2007 World Champions (with 987 and 177)
Unread 08-01-2008, 15:13
For the last 2-3 years, 330 has used the middle design. We don't use tensioners very much; last year the potentiometer mount served as a tensioner on the gearbox-to-center chain. We used #35 and figured out exactly where to place the wheels to eliminate tensioners. The big advantage is that a single thrown chain can't do a whole lot to you, unless it's the gearbox-to-center one, and even then you still have one wheel. We've only had one problem, and that was when a thrown/broken chain jammed between sprockets at the same time that we got stuck on an inner tube at the end of a match. It was fixed within one timeout.
White Paper Discuss: Dr Joe's Chain Path Visualizer Joe Johnson Extra Discussion 10 24-11-2008 18:31
6WD chain path Bill_Hancoc Technical Discussion 18 13-12-2006 17:08
Inventor file path help Rickertsen2 Inventor 3 08-04-2006 12:54
FIRST On A Disturbing Path DCaldwell05BCP General Forum 69 15-04-2003 14:58
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
