Go to Post I am a FRC Coach/Mentor I don't know the meaning of the words "days off" or "rest". At least not from January to May. - Bob Steele [more]
Unread 07-01-2008, 20:51
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Crab Drive HELP!!***
Ok, this is a huge issue on my FRC team. Many of the other team mates (including myself) want our robot to have a crab drive system on it, but some of the other members are opposed to this idea because it is well....new and they have no clue as to how they are going to build something like this.
Can someone please help me out and point me in the right direction as to where I can find some drawings or parts? Thanks in advance.
Unread 07-01-2008, 21:00
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Crab Drive HELP!!***
Search the white papers here, also google Crab Drive, especially Wildstang's site.
Crab sounds like a great idea, but if you've never implemented one before, be advised it's not as easy as it looks. Most teams successful with it built a prototype between the end of the last season and the beginning of the next season - 8 months? - and learned how to make it work while there was no time pressure. Your team might consider this approach.
One point: NASCAR doesn't use crab drive, why does your team think it needs to? Examine that question, and the answers might surprise you.
Don
Unread 07-01-2008, 21:03
tanmaker
Posts: n/a
Do a little research here at ChiefDelphi. I know there are tons of people willing to help, and they have had some of the same problems as you. I would also recommend doing a search on google, or similar search engine. I would personally suggest a mecanum are omni wheel drive, as they are easier, more reliable, and you should be able to find more info on those drive trains.
Unread 07-01-2008, 21:38
in between teams
AKA: Luke Van Oort
I agree with Don; if you haven't already built a crab/swerve or have a really solid idea of how to do it, don't. Crab/swerve is probably the most mechanically complex drive system you could try, and the software is even worse. I also agree with Tyler, mecanum is probably the simplest way to a omni system, but it still will require significant amounts of research. The bottom line is, do you want to spend six weeks on a drive system that you've never tried before and risk completely failing, or do you want something tried and true that can be complete by week two (or even before, depending on shipping times)? If you;re adamant on using an omnidirectional system, the PowerPoint on them at the FIRST Robotics Canada Resources Site would be a good start.
Team 1219: 2009 - Mentor
Unread 07-01-2008, 21:39
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I would also recommend looking at the Chief Delphi Media pages. There are very detailed designs of crabs that you may want to incorporate.
Here's the link:
http://www.chiefdelphi.com/media/photos/tags/crabdrive
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 07-01-2008, 22:09
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Good advice but the good thing about a mecanum drive is if you can't get it to work you can always put on regular wheels and drive.
Unread 07-01-2008, 23:04
ToolGuy91 ToolGuy91 is offline
tool guy
FRC #0384
Team Role: Mascot
ToolGuy91 is an unknown quantity at this point
the crab drive is a useful thing to have and as far as pictures go look at either 1086 or 384 robot from last year
Unread 07-01-2008, 23:15
CraigHickman
Posts: n/a
Don
Because of the hundreds of rules that don't allow drive systems not sold on production cars? Maybe?
Anyway, if you haven't built a crab before, or spent months designing one, you're way behind. Good luck building one, if you can.
Unread 07-01-2008, 23:21
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Yea I have to agree you are behind, but that shouldn't stop you from trying you can always go to a standard tank drive or even only a two wheel crab with omnis in the back (teams have used this effectively before) if things don't go your way.
Penn Class 08
Unread 07-01-2008, 23:33
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Check out Team 118
http://www.robonauts.org/
They are a Great Bunch of guys and would be happy to advise you. They have been using a crab drive for several years and have developed a fairly complex system. They may tell you you're in over your head but at least if they do, you'll know it's true.
Good luck!
Steve
Unread 07-01-2008, 23:42
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
I will echo what everyone else has pretty much said, check out the mecanum drive as it's probably your best bet for what you're looking to achieve in a short amount of time. It's no easy task, but it's easier than other omni-directional drives. My opinion of this year's game is that if you can create a very slick, very well practiced and smoothly operating mecanum drive, you'll have a significant advantage. Be prepared to put in a lot of time though.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 07-01-2008, 23:52
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Can't this team just use the Andymark Mecanum drive that is available as a COTS item?
Fabrication time of the drive wheels themselves would essentially be nothing at that point, (minus some obvious separate assembly time) and then it's just a matter of waiting for it to be shipped to you, mounting it on the robot, and then having drivers practice with them.
Am I missing something here with my suggestion?
Unread 08-01-2008, 00:44
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
As I remember it, both teams used mechanum drive, which is totally different than swerve.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-01-2008, 01:04
run the trap!!!
Team Role: Human Player
If you are planning to build a swerve AND a hurdling mechanism... Good Luck... I certainly wouldn't undertake it...
But if you just want to focus on herding the balls and quickly moving around the track why not? If your drive train is the only thing your building this season why not do something sophisticated like a swerve?
-Philip J. Fry
Unread 08-01-2008, 01:35
AdamHeard's Avatar
Lead Mentor
If you do decide to undertake a swerve/crab design make sure to spend a little extra time in the design process to build in a back up plan; Make you can switch the crab/swerve into just a normal 4WD in case it doesn't work out. This way you at least have a driving base in case of failure and won't be stuck with a completely disappointing season.
I'd say go for it if you have you have a reasonable amount of resources; you miss 100% of the shots you don't take.
Crab Drive nukelear1991 Programming 13 21-12-2007 18:02
HELP?!? with Omnidirectional/Crab Drive KMAC42 Technical Discussion 8 09-01-2007 21:34
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
