Go to Post Success is making a difference. - SlamminSammy [more]
Unread 08-01-2008, 00:22
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Re: Interesting IR sensor test results
Originally Posted by JHSmentor View Post
Do you think this would something you could/would build around the exisiting IR board and receiver that where given to us? kind of like a filtering shield that only lets in the frequency that you will be transmitting?
Yea that's what I was trying to say although i have no idea if that is possible with the given board. Someone else that's actually working with this thing will have to say.
Penn Class 08
Unread 08-01-2008, 00:24
Lions for First's Avatar
Lions for First Lions for First is offline
AKA: Devan
FRC #2365 (Lions Robotics)
Lions for First has a spectacular aura aboutLions for First has a spectacular aura aboutLions for First has a spectacular aura about
Send a message via AIM to Lions for First
i dont know all that much about IR but what kind of "filter" would you use that blocks all other frequencies but one?
2008 AZ Regional: Highest Rookie Seed
5th seed alliance Cap.
Semi-finalists (thanks 125 and 842)
Unread 08-01-2008, 00:36
abeD's Avatar
You don't block all frequencies but one (if you could do that simply then you would be making alot of money) but with some combination of low pass and high pass filters you can get a nice bandpass of filters centered around where you are transmitting. Do a wikipedia search on filters and try to get through it. All of the stuff I've learned about is college level engineering so it might not be the easiest thing to understand.
There are also several types of active filters as well that have a sharper "edge" to them on their bode plot. (a magnitude vs. frequency plot).
Penn Class 08
Unread 08-01-2008, 16:14
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
I like the idea of it but don't know how either. I read some patents and some college papers and it's a bit confusing (particularly because I could not view any of the images).
pic: Robostang's Analog Sensor test software Robostang 548 Extra Discussion 11 23-12-2007 09:55
Battery Life, 50A load discharge test method/results Dale(294engr] Electrical 5 22-01-2006 09:14
AP test results RudimentaryPeni Chit-Chat 29 19-07-2004 18:06
How do we Test our Beacon and Sensor Matthew_H Technical Discussion 7 07-02-2004 15:42
Results of traction test IBApril180 Technical Discussion 3 04-01-2003 18:56
