Go to Post I'd like to think that I'm at least a sometimes useful mentor. - artdutra04 [more]
Unread 08-01-2008, 03:18
Tach'ko's Avatar
Tach'ko Tach'ko is offline
Vice President of the planet Earth.
AKA: Jeffrey
FRC #2344 (Saunders Droid Factory)
Team Role: Electrical
Tach'ko is an unknown quantity at this point
So uh yeah... How 'bout that lap counter? Also Metallica.
Because I'm incredibly interested in seeing how exactly this thing works, and uh... Its not listed in the kit of parts, and its not in the kit of parts. Does anybody know if they're just going to give us one there?
I mean, its not like we need it, just kinda wonderin' whats going on.
Also, I was seriously considering making it play Metallica during the match, I know theres a rule against obnoxious noise, but I figure if its not that loud, they might not say anything about it.
Opinions?
If anybody understands the meaning of Webber T, let me know. I think my teacher made it up...
I'm bored... Check out mai devArt!
Unread 08-01-2008, 05:01
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Re: So uh yeah... How 'bout that lap counter? Also Metallica.
I believe the lap counter will be supplied by someone at the events.
Seem to remember reading in the rules it will be attached at the start of the match.
Metallica should never be considered noise!
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Unread 08-01-2008, 07:04
Travis Hoffman Travis Hoffman is online now
O-H
FRC #0048 (Delphi E.L.I.T.E.)
<R18>
ROBOTS must use the LAP INDICATOR provided by the field personnel
during all official tournament MATCHES. The LAP INDICATOR is attached
to the stopper on the flag pole.
When the FLAG is placed in the flag holder, the stopper will insert
into the top of the holder.  To accommodate the LAP INDICATOR, the
area within a minimum 180—degree horizontal arc around the top of the
flag holder must be kept clear of any obstructions within a 2-inch radius.
This region must be kept uncovered and visible from above. To ensure that every
FINISH LINE CROSSING is properly recorded, the LAP INDICATOR must be visible to the
Lap Detectors when the ROBOT passes under the OVERPASS. The LAP INDICATOR is
powered via a standard three-wire PWM cable. An easily accessible, powered, male PWM
connector must be located within 4 inches of the LAP INDICATOR mounting location. The
port may be either a direct connection to an analog or digital port on the Robot
Controller, or a remote “pigtail” connection to the Robot Controller port.
Hear hear!
Now how neat would it be to supplement a "gentle bump to pass" with the "aaaaaooooooooooooogaaaa" sound of a horn? I actually think such a device, if able to be heard over the din of the match without being a painful noise, would serve as an additional useful signal to let teams (and more importantly, referees) know that a bump request has been made.
<R02> doesn't explicitly prohibit the devices; however, if they are deemed to be too loud or are used too frequently to annoying or distracting effect, a team may be prevented from using them.
<R02>
Items specifically PROHIBITED from use on the ROBOT include:
Shields, curtains, or any other devices or materials designed
or used to obstruct or limit the vision of any DRIVERS and/or COACHES
and/or interfere their ability to safely control their ROBOT.
Speakers, sirens, air horns, or other audio devices that generate
sound at a level sufficient to be a distraction or hindrance
affecting the outcome of a MATCH.
Unread 08-01-2008, 07:52
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
Does anyone else wonder about the field of view on these ir lap counters? and what might happen if say another robot were in between you and the counter, or you are right next to the wall ect.?
Unread 08-01-2008, 08:02
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
There's a thread started already with some details on these things:
http://www.chiefdelphi.com/forums/sh...ad.php?t=60726
Pete Kieselbach
Unread 08-01-2008, 08:05
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
i wouldn't worry too much about the counters. the should work pretty well. they've probably takin' that into consideration already.
if you play metallica from your cart, you would be ok, but the robot would be awesome
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 08-01-2008, 08:37
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Sadly, no music is allowed on your carts either! Its not allowed per section 3.3.6 and 3.9.12: "Do not add music to the cart".
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 21-01-2008, 11:38
pufame's Avatar
pufame pufame is offline
FRC #0291 (CIA)
Team Role: Webmaster
pufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud of
If I had to guess I'd say they'll also have refs at each line doing hand counts of robots that cross, the indicator is meant to be a way to keep a fairly accurate score on the scoreboard during the match, sort of like the counters for balls through goals in "Aim High".
Unread 21-01-2008, 09:36
MentorPete MentorPete is offline
FRC #1683
MentorPete is an unknown quantity at this point
Lap Indicator Hookup?
Does anyone know the pinout of the lap indicator provided at the field? It's a 3 pin PWM style connection. I assume 2 pins are power and the third is a signal line? Is it an input or output? Do we use the third line? If so, what do we do with it?
My guess is that we just power the indicator and ignore the third line, but I'm not sure.
Thanks everyone in advance for any help.
Unread 21-01-2008, 10:26
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: Lap Indicator Hookup?
My understanding is that we don't use the third line, just provide power.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 21-01-2008, 11:52
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Opinions?
I think that depends on what Metallica you're playing. If it's stuff from Kill 'Em All, Ride the Lightning, Master of Puppets, And Justice for All, or Metallica; you're fine. If it's from Load, Reload, or St. Anger; it's obnoxious noise and should be immediately shut off. Garage Inc. depends on the song. Their Ninth Album will be out by competition time, and hopefully it will return to their roots rather than continue down their current musical path. We'll see.
Now I return you to your regularly scheduled thread conversation.
Unread 21-01-2008, 12:01
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
We don't play Metallica off our robot, we just get the DJ to play Enter Sandman, football-game style. Oh wait, that's a Virginia Tech thing. It might seem trivial to other teams, but it really pumped us up during the semifinal rounds at VCU two years ago.
Lap counted when lap indicator crosses line? Madison Technical Discussion 6 08-01-2008 09:15
pic: IR Lap Counter on the Manchester Kickoff Field ahecht Extra Discussion 13 06-01-2008 21:38
How 'bout them Tigers xzvrw2 Chit-Chat 18 25-09-2006 00:05
Pump-Up Music! Yeah, that is what I am talking about! Freddy Schurr Chit-Chat 25 07-05-2006 22:07
How bout that FIRST brand water? Wetzel Championship Event 9 09-05-2002 16:52
