Go to Post Everyone better enjoy the broadcast, Dave had to cancel a shuttle launch to make it happen :D - The Lucas [more]
Unread 08-01-2008, 06:27
AmitCarmeli AmitCarmeli is offline
FRC #1943
AmitCarmeli is an unknown quantity at this point
IR Difficulties
Hey everyone...
I am quite new in this field, so I need your assistance with our IR sensor. I have not been able to get the explainations about the IR sensor, but I have connected it with a PWM-cable into the RC's Digital Input.
But after defining those Inputs in the software, I got no response from them when I checked their outputs. Could I have done something worng with the program or the adjustment of the IR sensor?
Unread 08-01-2008, 08:47
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
Re: IR Difficulties
I'm not quite sure about that last part of the statement, but the IR sensor must be "trained" before it will output anything. Make sure you do that.
How are you defining the code?
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Unread 09-01-2008, 22:42
interfect interfect is offline
FRC #2022
interfect will become famous soon enough
Re: IR Difficulties
Also, how do you have your power and data hooked up? We used the rainbow cable, two PWMs, and some of the screw terminal block to essentially make a custom cable and get it talking to the OI. A single PWM won't work for data, but you can use it to power it up and train it.
Do you know the pinout for the IR board?
Unread 11-01-2008, 20:49
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Re: IR Difficulties
Pinout for the ribbon cable of the IR board can be found on this page on the FIRST web site:
Page with link to PDF instructions for IR Board:
http://www.usfirst.org/community/frc...t.aspx?id=7600
Direct link to PDF instructions for IR Board:
http://www.usfirst.org/uploadedFiles...%20_121007.pdf
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Technical Difficulties muy dificil Programming 0 13-10-2005 11:25
Single Joystick Code Difficulties willie837 Programming 11 11-02-2005 14:29
Default Code Difficulties Drok00 Programming 3 02-02-2005 20:56
FIRST Technical Difficulties at Rutgers aka Scott White General Forum 10 27-03-2002 14:40
