Go to Post This year should be an unusual object game. You know what an unusual object is? Water. - TheBoulderite [more]
Unread 08-01-2008, 07:52
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
Re: So uh yeah... How 'bout that lap counter? Also Metallica.
Does anyone else wonder about the field of view on these ir lap counters? and what might happen if say another robot were in between you and the counter, or you are right next to the wall ect.?
Unread 08-01-2008, 08:02
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
There's a thread started already with some details on these things:
http://www.chiefdelphi.com/forums/sh...ad.php?t=60726
Pete Kieselbach
Unread 08-01-2008, 08:05
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
i wouldn't worry too much about the counters. the should work pretty well. they've probably takin' that into consideration already.
if you play metallica from your cart, you would be ok, but the robot would be awesome
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 08-01-2008, 08:37
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Sadly, no music is allowed on your carts either! Its not allowed per section 3.3.6 and 3.9.12: "Do not add music to the cart".
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 21-01-2008, 11:38
pufame's Avatar
pufame pufame is offline
FRC #0291 (CIA)
Team Role: Webmaster
pufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud of
If I had to guess I'd say they'll also have refs at each line doing hand counts of robots that cross, the indicator is meant to be a way to keep a fairly accurate score on the scoreboard during the match, sort of like the counters for balls through goals in "Aim High".
Lap counted when lap indicator crosses line? Madison Technical Discussion 6 08-01-2008 09:15
pic: IR Lap Counter on the Manchester Kickoff Field ahecht Extra Discussion 13 06-01-2008 21:38
How 'bout them Tigers xzvrw2 Chit-Chat 18 25-09-2006 00:05
Pump-Up Music! Yeah, that is what I am talking about! Freddy Schurr Chit-Chat 25 07-05-2006 22:07
How bout that FIRST brand water? Wetzel Championship Event 9 09-05-2002 16:52
