Re: Mecanum Motors
use encoders or the KOP gyro
Re: Mecanum Motors
Team 401 used mecanum last year to some success. Using encoders on them isn't very reliable as mecanum its self slips a lot and your feedback will be off.
Using 4 CIM motors with banebot gear boxes is the way to go, just keep the robot balanced. |
Re: Mecanum Motors
We had a mecanum drive last year with great success. Balance is the key. Our drive only drifted a little and we had no encoders. We are using the same drive system this year with encoders. The mecanum wheels we purchased last year from AndyMark required a lot of work to assemble and modify. We did not find AndyMark wheels to be precisie enough, holes didn't line up, rollers were not perpendicular to their mounting plate sections. Where else, besides AndyMark, can we get 8" mecanum wheels?
Re: Mecanum Motors
I've heard the 6in ones are much better because it's a whole plate, no tabs like the 8in ones.
Re: Mecanum Motors
You can't, the only place that sells mecanums for FIRST robots is andymark. There are other companies that use mecanums but for the most part they simply use them in their own vehicles and don't sell the wheel separate. In addition these compainies make things like forlifts and you aren't going to find a small enough wheel.
For the actuall control I would strongly suggest using a gyro instead of encoders, the code is easier and it isn't suseptible to slipping. I have done a holonomic for the past 3 years and last year ours was a rock, it didn't drift, it went in a perfectly straight line and overall just ran extremely well and we didn't use encoders, just a gyro. |
Re: Mecanum Motors
I'm curious - if you did not use encoders, how did you measure distance driven?
#7
Re: Mecanum Motors
You could use a linear accelerometer and integrate it over time to get distance. However if you want distance you probably want to use an encoder, but for the basic control of a mecaum bot you don't need distance traveled. What usually makes a mecanum uncontrollable is drifts in rotation because this can cause the bot to swerve to one side or drift in the wrong direction, for this you can integrate a gyro. While this may sound dificult it is easier than programing in interupts (or at least that is what I have always found).
#8
Re: Mecanum Motors
Yes, it looks like Andymark is the only place to buy a Mecanum wheel off the shelf... but... as with other things you COULD actually buy something that uses a Mecanum wheel and strip it off of it to use. Nothing in the rules says you have to use the whole item that you buy, but it does say you have to account for it in your budget. Hypothetical Situation: You buy a Remote controlled car with Mecanum wheels already on it and strip them off for use on your robot. You must include the whole price of that Remote controlled car (which may be outrageous yes, this is true but this is just an example) in your final Bill Of Materials. The Wheels would go in your Bill of Materials for your robot. The whole cost of the Remote controlled car would need to be listed in the price portion of your data to prove you came in under budget. All I'm saying is that you don't have to limit yourself to something just because it's "not available anywhere else" as a singular entity. If you find a shopping cart has cool wheels you want to use, but can't find those exact wheels for sale anywhere else, just buy the whole shopping cart, strip the wheels off, put the wheels in your Bill Of Materials, and write down how much you paid for the shopping cart (even if you did get it for "free" from a store... (as a legitimate donation of course..) ![]() |
| Motors, Motors, and More Motors | 1033missions | Motors | 1 | 09-02-2006 18:46 |
| Motors.. and more motors.. How many on your 2004 bot? | OneAngryDaisy | Motors | 33 | 23-02-2004 00:46 |
| Matching Drill Motors and Fischer-Price Motors | archiver | 2001 | 5 | 24-06-2002 00:51 |
| Fisher Price Motors for Drill Motors | archiver | 2001 | 0 | 24-06-2002 00:22 |
| F.P. Motors & gearbox for $12.50 Window Motors $19.50 | archiver | 2001 | 1 | 23-06-2002 23:05 |
