Re: Will your robot fit in the box?
The other box you have to fit into is your shipping crate. Not as much an issue as last year when you could have a 72" robot. But you still have to fit 60" of robot into a 70" (outside dimension) crate, with forklift skids.
Mmmmm. Sizing box. It's so true what's been said about the unforgiving box. I will (sadly) say that we had to (slightly) modify the robot thanks to the sizing box. But teams, I can tell you now! While SOMETIMES an inspector may be nice enough to let a ziptie head that pokes out 1/16th of an inch over the 38 inch limit slide, don't let it happen. Play it safe, and leave a 1/2" safety zone on all sides of the robot to account for any parts that stick out.
You could do what we do -- Max dimensions are 36" x 26". That's an extra 2in for each dimension. For bolt heads, zip ties and so forth. Worked well last year, too. Even when our frame was warped. And we never needed to use a hacksaw.
I've always allowed 1 inch off of each dimension. It's come in handy quite often, for when you suddenly decide you have to bolt some new componend onto the outside of the robot.
Another recommendation: if you're building an arm or any kind of mechanism that folds up, make sure you have enough clearance for the pieces to fold into starting position. I misjudged one section on last year's tube gripper (a pneumatic fitting!), and suffered in every inspection because of it. I couldn't make any modifications without destroying other parts, so we were one of those teams trying to get the robot to fit "just right". It's no fun, trust me. 2006, with our 27"x37"x59" box, was much less stressful, by far. |
| WMR,what will your robot do? | Jim Schaddelee | Regional Competitions | 0 | 20-03-2007 11:21 |
| Which wheels will you use for your robot this year? | GO Groves 1213 | Technical Discussion | 44 | 03-02-2007 12:36 |
| Help! What kind of belt will fit on Denso Window Motor | tstanis | Motors | 2 | 16-02-2006 14:52 |
| How many will fit? | Joe J. | General Forum | 1 | 15-01-2004 15:17 |
| How fast will your robot be? | Anton Abaya | General Forum | 18 | 20-01-2002 22:26 |
