#10
Re: block thrown ball
This assumes, however, that you can get the volume of air to fill the cylinder quickly enough. A 2" cylinder takes a decent amount of time to fill up, given that all the air has to flow through tubing at 60psi. Just because you can achieve 220 lbs of force from a cylinder doesn't mean that you'll be able to deliver enough energy to lift the ball in the air.
| Who has successfully THROWN ringers on to the rack yet? | murray2077 | Regional Competitions | 108 | 01-04-2007 23:17 |
| ball corral block, good or bad? | Lil' Lavery | Rules/Strategy | 22 | 02-04-2004 23:35 |
| Stinger Fuse Block and Power Distribution Block | Don Wright | Electrical | 2 | 30-03-2004 10:45 |
| 2X Ball Into the Ball Release | MikeDubreuil | Rules/Strategy | 23 | 28-03-2004 19:31 |
| Anyone knowwhere to buy maxi block distribution block? | BrianB | Kit & Additional Hardware | 0 | 23-01-2003 12:46 |
