Go to Post Even when the system is "really good" it can always be tweaked a little to make it even better. - dlavery [more]
Unread 08-01-2008, 13:54
in between teams
AKA: Luke Van Oort
Re: Crab Drive HELP!!***
Originally Posted by Elgin Clock View Post
Can't this team just use the Andymark Mecanum drive that is available as a COTS item?
Fabrication time of the drive wheels themselves would essentially be nothing at that point, (minus some obvious separate assembly time) and then it's just a matter of waiting for it to be shipped to you, mounting it on the robot, and then having drivers practice with them.
Am I missing something here with my suggestion?
Sort of. As you pointed out, a basic mecanum isn't that mechanically challenging (although a suspension might be very important to have, depending on your frame). The software, however, can be rather tough. Not an insurmountable problem by any means (as all the mecanum robots proved last year), but it can be troublesome; just figuring out how to setup the controls for the driver can take a good bit of time.
Team 1219: 2009 - Mentor
Unread 08-01-2008, 14:18
GGCO,
Although crab drive is a great tool we don't use it all the time. It will only be incorporated into the robot design after careful consideration and playing the game. Don't make the decision at this point, play the game using chairs or tricycles or whatever and see if it is needed. If the team decides to use it then be advised that crab requires some strong mechanical attachments for both the top and botom, special handling to determine how assemblies are attached for steering, how to build a module so that both the wheel and the motor you use will fit into the space you require for turning the module and realize that crab by design puts the wheels closer to the center of the robot which compromises stability. After all of that is overcome, your drivers still need plenty of practice.
A so-so robot with lot's of practice will beat out a superior robot with no practice, every time.
As a personal request, can you include your first name in your profile? It makes it easier to respond. Thanks.
Unread 08-01-2008, 15:04
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Ok, thanks all for replying! I am doing research and I am starting to see that a well designed robot/crab drive is not going to happen. I'll try to convince the rest of the team. THANKS!
Unread 08-01-2008, 19:27
CarpeNoctem's Avatar
CarpeNoctem CarpeNoctem is offline
Ranger
FRC #1057 (Blue Knights)
Team Role: Scout
CarpeNoctem is an unknown quantity at this point
Thumbs up Re: Crab Drive HELP!!***
My team had a crab drive system last year. It worked great and for the game this year it should be good for going around... you dont even have to turn.
But it probably would not be good for hurdling.. Its best use could most likely come from herding the ball around with it
When designing something completely fool-proof, we often underestimate the ingenuity of complete fools!
-Douglas Adams
Crab Drive nukelear1991 Programming 13 21-12-2007 18:02
HELP?!? with Omnidirectional/Crab Drive KMAC42 Technical Discussion 8 09-01-2007 21:34
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
