Go to Post we have to get our robots to watch tv and drink beer. - nreynolds [more]
Unread 07-01-2008, 21:03
Digan's Avatar
Digan Digan is offline
AKA: Dimitri
FRC #2182 (Tyborgs)
Team Role: Driver
Digan will become famous soon enough
Fast Motor.
Just a simple question. What type of motor should I get so that my robot can get an average of 15 fps?
Unread 07-01-2008, 21:14
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
Re: Fast Motor.
The CIM motors in the KoP can easily do 15 FPS.
Unread 08-01-2008, 08:23
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Fast Motor.
ya, a CIM, and possibly a banebots tranny
Unread 08-01-2008, 08:48
Billfred's Avatar
Billfred Billfred is offline
Re: Fast Motor.
In theory, any motor will get you to 15 fps...eventually.
The best advice I can offer is to download JVN's design spreadsheets (newer, older) and start fiddling with numbers. The newer spreadsheet is a little more user-friendly, though the older one lets you have a little more fun with numbers (particularly when you're trying to figure out how quickly a robot will accelerate).
Another thing worth noting in the spreadsheet is the output at maximum load. Conventional wisdom says that the safe route for a drivetrain entails being able to slip your wheels/treads/doohickey in your lowest gear when pushing against a wall, and do so while drawing less than the 40 amps it takes to trip your robot breakers. If you want a higher speed than what will allow that, you'll either have to add motors or shift. (A good thread on the matter is here.)
But to answer your original question, it is possible to use four CIM motors with the right gearing and wheel choices and hit 15 feet per second. (Matter of fact, you can even do it using COTS parts exclusively.) I'll leave the math to the reader, since all the tools are already posted.
Hope this helps!
Unread 08-01-2008, 10:01
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: Fast Motor.
I think you have the answer to your question, however, you should also make sure you have a well trained driver. 15 fps is very fast, and unless your driver is capable of making the robot go where she wants at this speed, it might not do you much good.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 08-01-2008, 15:33
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Fast Motor.
Why 15fps? Is there a strategic reasoning behind that number?
Wetzel
Viva Olancho!
Unread 08-01-2008, 15:43
caraddicted101 caraddicted101 is offline
caraddicted101 has a spectacular aura aboutcaraddicted101 has a spectacular aura about
Re: Fast Motor.
Wetzel
That is a good point - does your team think that there is an advantage to that? The other thing that you have to consider is that if you are trying to go this fast on a one speed tranny then you will probably not have a whole lot of torque. I agree with everyone else though, the cim motors are the most effective for speed.
Unread 08-01-2008, 15:58
Best Available Data
FRC #1778 (Chill Out!)
Re: Fast Motor.
You better have a darn good software team, and one heck of a driver to keep control of a robot at 15 fpgs.
We gave our driver a 15 fps mode last year. While the game didn't really warrant it, he still used it twice. One of those times he collided with the alliance station, and the robot required some hammering out before our next match.
But, as other posters have pointed out you want the CIMs. In fact, no matter what drive speed you end up using, you want the CIMs. Most likely two per side to get some good acceleration so you can actually take advantage of your 15 fps. If you do end up using the second CIM, you'll need to buy a few additional parts from AndyMark.biz.
Unread 08-01-2008, 17:17
Digan's Avatar
AKA: Dimitri
FRC #2182 (Tyborgs)
Team Role: Driver
Re: Fast Motor.
Yeah I have a good reason.
'bout to have a meeting with my team in a few hours. So if the idea gets rejected. I'll let yall know and maybe someone can do better with it.
We geared this one really fast, so fast it caught on fire! Travis Covington Robot Showcase 18 12-02-2005 07:22
How fast is fast to get on the hill? ianbbat General Forum 76 09-03-2003 21:05
How fast is the torque motor? archiver 2001 3 23-06-2002 22:55
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
Help! Need Motor Coupling FAST! Eric Reed General Forum 3 06-09-2001 00:40
