Go to Post drill holes, that should fix it - E. The Kidd [more]
Unread 06-01-2008, 17:51
Armando Gonzalez's Avatar
Armando Gonzalez Armando Gonzalez is offline
FRC #1872 (Yellow Fever)
Armando Gonzalez has a spectacular aura aboutArmando Gonzalez has a spectacular aura about
Send a message via MSN to Armando Gonzalez Send a message via Yahoo to Armando Gonzalez
Re: Omni wheels?
Although mecanum wheel provide excellent mobility and a relatively fast movement speed, the system to make them work weighs too much. Each wheel weighs about 2.5 pounds + 2.5" CIM Motor + transmission = alot of weight simply to make the robot move
Armando Gonzalez
Team 1872 - Yellow Fever
San Juan, PR
Awards
Rookie Inspiration Award - 2006 UCF Regional
Unread 06-01-2008, 18:06
kristenliz_28's Avatar
kristenliz_28 kristenliz_28 is offline
Team girl squad *cape whoosh*
AKA: Kristen
FRC #0020 (Team 20- the rocketeers)
kristenliz_28 has a spectacular aura aboutkristenliz_28 has a spectacular aura about
Re: Omni wheels?
our team was considering using omni wheels, but it would be hard to herd/move the balls out of the way. Of course, I guess the reason to use omni wheels is so you can juts go around quickly
Unread 06-01-2008, 19:07
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Omni wheels?
Originally Posted by tawnos23 View Post
I would suggest to buy metal omniwheels instead of the plastic ones. Our first year with omniwheels we bought the plastic ones, and they broke to pieces during the course of a regional.
Yes, that first year, I thought that it was a good idea to put a 10% fiberglass fill into the black polycarbonate. While that made the tensile strength higher, it was lower rated on the Izod impact rating. The fiberglass mad the material brittle, and when teams hit the side of the 1 point ramp in 2006, the wheels broke. The result of these breaks were improving these wheels and creating the aluminum omni wheels.
So... last year we had black polycarbonate with no fiberglass filler, and that resulted in zero complaints about breakages.
If I had to pick which omni wheel to use on a FRC robot, I would choose the 6" aluminum omni wheel, and use an Omni Spacer to make them a dualie omni wheel. That is a sweet setup. The polycarbonate wheels are nice, and can handle 2 bearings, but the aluminum wheels take up less space (they are thinner) and they are repairable. The only negative about the aluminum omni wheels is that they only have the ability to have 1 bearing mounted to them, that is unless you add on an extra hub.
Andy B.
Unread 06-01-2008, 20:05
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Omni wheels?
Last year we used the plastic polycarbonate omni wheels and we are a very happy customer. Zero problems. In fact we are ordering more for this year tomorrow.
Ed Barker
Unread 07-01-2008, 13:59
Zoysiamo's Avatar
Zoysiamo Zoysiamo is offline
In the champeenship?
AKA: Jeff Atkinson
FRC #2614 (MARS)
Zoysiamo is an unknown quantity at this point
Post Re: Omni wheels?
In 2006 I helped create an omni drivetrain for team 859 using the poly AndyMark omniwheels, only to have the roller mounts (around the circumference of the wheel) shatter several times on the ramp. Other teams had better luck with small caster-style wheels such as from omniwheels.com or mechanum (angled roller) wheels.
At least without ramps this year's game should be easier on omniwheels.
Unread 07-01-2008, 15:14
Bob Steele's Avatar
AKA: Bob Steele
Re: Omni wheels?
We used the AM plastic omniwheels last year with absolutely no problems.
We will have to replace the rollers because in the course of 2 regionals and the championships, we wore them down...
this year we are going to a new idea.. using two of the poly wheels staggered to produce a wider wheel.
Please take a look a the attached jpg ... we are direct driving the omniwheels with Dewalt transmissions...
This is a holonomic robot....
Name:	dually polycarbonate small.jpg
Unread 07-01-2008, 18:20
Re: Omni wheels?
what are the benefits of direct driving the omni wheels instead of using two normal wheels and two omni in the front?
Armando Gonzalez
San Juan, PR
Awards
Unread 07-01-2008, 18:31
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Re: Omni wheels?
In my years of robotics i havent found an advantage to driving omniwheels other that more power.
Unread 07-01-2008, 19:29
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Re: Omni wheels?
Originally Posted by Daiane View Post
I agree with her...
Mecanum Wheels is more efficient than other omni wheels...
I always wanted to use this type of wheel in my team but i never used because don't have these wheels in Brasil... so we have to import and it's not simple here...
Good Luck teams
When you say they are more affective, is that just for versitility in moving the robot (more or less why they are designed this way) or are they also affective for top speed?
Unread 07-01-2008, 23:10
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Omni wheels?
I have only seen one advantage of powering omni wheels, to climb things like in the 04 game.
here is a picture of my old hs bot from the 04 game with my omni wheels in the front so we could turn easily and climb the steps without a problem. it was really fun to watch actually.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 08-01-2008, 16:27
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Help with Omni wheels?
Our team has been thinking about using an omni drive but we have a question. How do you figure out how fest an omni drive will go. Our team knows how to calculate the speed if all the wheels are strait, but how do you account for the omni wheel slipping?
Thanks
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 08-01-2008, 16:54
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Omni wheels?
That is going to be one really fast robot!
Art Dutra IV
世上无难事,只怕有心人.
Unread 08-01-2008, 19:59
sweetie_pi sweetie_pi is offline
AKA: Nica
FRC #2189
sweetie_pi is an unknown quantity at this point
i have never used omni wheels but my team is thinking about it. What is the difference between metal and plastic wheels on the carpet? Does one work better than another?
Unread 08-01-2008, 20:08
Quick answer: metal wheels are not allowed. All the omni wheels in this competition have plastic rollers. So the main difference would be weight, I think.
Unread 08-01-2008, 20:23
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Omni wheels?
I agree dual 6" aluminum omniwheels are sweet. In '06 my team spent a lot of effort building our own, so it was nice to have the option of buying them from AndyMark last year.
Our '07 chassis used single 6" aluminum AM omniwheels on the corners of a 6WD kitbot, and kit AM wheels in the middle with one CIM per side -- not a defense-oriented drivetrain, but nice for maneuvering. To get around the single bearing limitation Andy mentioned above, we mounted the inboard bearings in the sprockets that drove each omniwheel. This required boring out the center hole in the sprocket to 1.125", which is a relatively easy lathe operation in a standard 3-jaw chuck if the tooth count is a multiple of three.
Richard Wallace
since 2003
Help with Omni-wheels The GarbageMan Kit & Additional Hardware 12 10-04-2007 12:39
can bots with omni wheels capable of going up robots? Tri_Lam Technical Discussion 12 13-01-2007 16:15
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Motors with Omni-Wheels jlewellen Motors 5 11-01-2006 23:24
Omni Wheels edomus General Forum 6 06-02-2004 13:35
