#31
Re: Defense, It's still here.
Assuming you sat there all match, that's 120/6-1=19 possible for impeding, plus 1*#high contact, plus 1 for the 80", maybe including a disable and/or DQ. 20 penalties minimum at 10 points apiece=200 penalty points minimum, not counting high contact. The purpose of the above math is to help ensure that no one tries this at home or at regionals. |
#32
You are not impeding anyone so long as there's room for them to get by. Our robot's take up only 3' of the available 13', so unless there's a serious mess down below the overpass, it's exceptionally unlikely that you'll genuinely be impeding anyone from getting by. If you bump into me and the field around me is wide open, don't expect me to move anywhere. |
#33
but, unfortunately you can only bump a robot if it is blocking the path of yours sooooo, bumping a hurdling robot only works if they are blocking you.
#35
Again, this makes very little difference to me. There remain a number of rules which, in my opinion, are too reliant on the subjective judgement of a referee. I can't be impeding a robot intentionally unless I know that it's trying to get by me, and I can't know that until it makes an attempt at such or "bumps to pass". A robot 20' behind me may have every intention of passing me as it catches up to me and I might be weaving back and forth in an unrelated action and there exists every opportunity for a referee to interpret that as impedence. That is unsettling. |
#36
as soon as that ball touches your bot ,i think that is a complete hurdle.
#37
Only if the ball has completely passed through the plane of the finish line. If you deflect it backward before then, it hasn't CROSSED the finish line and thus, does not meet the definition of a HURDLE.
#38
My guess is that you'll not be able to build it strong enough to withstand a strong blow from the ball (remember, some teams will shoot the trackball and it has a decent amount of mass) and if you do build it strong enough then you will be very top heavy and will likely end up on your side, blocking traffic and incurring penalties for the remainder of the match.
#39
There isn't anything directly stating that herding your opponents trackball into the "corner" and simply sitting there, having your bot between the ball and everything else, is illegal. Right? Please correct if im wrong. There is still ample room to pass, so no impeding, and the bump rule only is in effect if you are impeding and there is no other lane to pass.
Also a simple bump of the opponents trackball backwards across a line, completely legal as long as they weren't in the process of hurdling? This should be easy due to the balls bounce-ability (yeah, we do that haha) Legal still? Defense is subtle, but still a very good strategy if your scoring device/strategey is weaker than your TWO alliance teammates, and they are controlling the TWO balls assigned to your alliance. Anything against the rules here? Or are we still finding decent loopholes |
#40
I'm not saying that this rule allows you to continue racing, getting off scott-free if you tore through the toppled robot, but it looks like FIRST knows that a toppled robot is a major hazard to a game like Overdrive. |
#42
I don't doubt there will be a bit of strategic defense this year. But I dont think it will be anywhere near as satisfying as pushing another team sideways into a wall.
Also, I'd advise against bets with Adam Heard. He tends to pick his battles well. |
#43
As for the thread, there obviously won't be the hard hitting and pushing that occured last year, but there will be plenty of incidental contact with 6 robots going around the track that would favor the same kind of drivetrain that is a good defensive robot. So, no direct defense; but plenty of interaction. |
#44
I believe this year game will benefit intelligent defense, as building a robot only to push others won't be so successfull... The game is clearing in my mind, and I believe that it will be much better than we expect... All we need to do is think smart... and there will be many different strategies to attack or defense, that you might use without break any rule... |
#45
I didn't get to read this whole thread, so sorry if this has been mentioned.
A simple defense in hybrid mode should be very possible for all teams. They could just place their robot the farthest to the left it can be as a starting position, and then in hybrid mode just drive forward about 5 feet. They would then be blocking the middle of the lanes in perfect placement to stop autonomously controlled robots from continuing around the course. |
| It's HERE! Sparky384.com Store Now Online | Joe Matt | Chit-Chat | 3 | 19-01-2004 10:35 |
| Mac Programmers be happy! It's finally here! | MacZealot | Programming | 42 | 25-08-2003 11:32 |
| anyone still here? | Greg Needel | General Forum | 29 | 17-02-2003 11:53 |
| It's kinda lonely down here | Kevin Watson | Math and Science | 1 | 27-12-2002 20:53 |
| Yes, I'm still here... | archiver | 2000 | 0 | 23-06-2002 23:04 |
